FKW's avatar
FKW
Network Switch Discovery Tool for MAC
Hi, i have downloaded the network switch discovery tool for MAC today but upon unzipping it the .EXE appears to be the windows version
The version of the NSDT is 1.2.102, can you advise please as this version will not run on my MAC?
I have checked the windows version in case they were switch but that too also aappears to have a windows .EXE file alothough it is smaller.
kind regards
FKW
1 Reply
  • schumaku's avatar
    schumaku
    Fetch the Mac version from https://www.netgear.com/support/product/netgear-switch-discovery-tool.aspx
    11.02.2020 15:48 49’152 md5.exe
    11.02.2020 15:48 63’351’570 NetgearSDT-V1.2.102.dmg
    11.02.2020 15:48 72 NetgearSDT-V1.2.102.dmg-md5checksum.txt
    11.02.2020 15:48 264’227 Release_Notes-V1.2.102.pdf
    11.02.2020 15:48 75 Release_Notes-V1.2.102.pdf-md5checksum.txt
    You can ignore the md5.exe - the utility is in the DMG kit.
ProSupport for Business
