comunica
Feb 19, 2016Follower
PXE Boot using lacp dynamic (port in indivual state)
We are trying to correctly setup port-channels for our cloud server farm that would use linux with bonding mode=4 (802.3ad). Once installed everything work as expected when using dynamic port-channels but that same configuration on the switches make impossible to reinstall them through pxe or change the bonding mode on servers according to node's role (hpc node = mode 0/6 or cloud node = mode 4)
If we use instead static port-channels all bonding modes work although (mode=4 802.3ad) only sees/uses one active port which is not desirable.
We've been playing with differente combinations of lacp actor/partner admin state (individual/passive/longtimeout) without success. Is it possible such combination with Netgear switches? The switch is in fact a stack of six M5300-52G ProSafe 48-port Gigabit L2+ with 10 Gigabit Stacking, running 11.0.0.12
Other vendor switches are able to cope with this, Juniper EX series using "force-up", Cisco/Nexus with "no lacp suspend-individual" which is the default, HP/H3C as well, specifying lacp edge-port...
So, the question is, is it possible? and if so, what's the configuration for such setup? Ideally we would like they were dynamic port-channels and if the switch/stack doesn't hear anything (lacp bpdus) from the other side to put the ports in individual state which apparently is not the case.
kind regards.
-- Juan
1 Reply
- DaneANETGEAR Employee Retired
Hi comunica,
Welcome to the community! :)
Kindly try to update the firmware to version 11.0.0.18 and it might help. Be reminded to perform a factory reset on the M5300-52G after a successful firmware upgrade then reconfigure it from scratch. Here is the link where to download firmware version 11.0.0.18.
DaneA
NETGEAR Community Team
