Morvenmcc
Sep 17, 2019Aspirant
VLAN issue
Hi trying to setup ports 13-24 on VLAN 1 as part of our network.
They have all been tagged as 'U' in our VLAN Membership.
They also all have a PVID of 1.
But for some reason ports 17 and 21 are not working.
I noticed on the VLAN Status page that on VLAN 1 the member ports were:[1/0/13-1/0/16, 1/0/18-1/0/20, 1/0/22-1/0/24] rather than [1/0/13-1/0/24]
Does anyone know why this is?
Thanks
- Retired_Member
Hi Morvenmcc
Welcome to Community!
What's switch type in your envrionment? Could you please share the screenshot for the 'VLAN Membership' config page(GUI go to Switching-->VLAN-->Advanced-->VLAN Membership), as currently port 1/0/17 and 1/0/21 not include VLAN based on your description. It's will be better that you can collect more info with CLI command 'show running-config interface 1/0/17&1/0/21'.
Hope it helps!
EricZ
- MorvenmccAspirant
- Retired_Member
Hi Morvenmcc
Looks like the VLAN configuration is correct.
Then please do check if there is some other configuration on port 1/0/17 and 1/0/21, example: stacking port? mirror port? or other will impact VLAN members...
For further analysis,Could you please provide the tech-support file of the Switch:
How do I send tech-support files from my Managed Switch to NETGEAR community moderators?
https://kb.netgear.com/31439/How-do-I-send-diagnostic-files-from-my-Managed-Switch-to-NETGEAR-community-moderatorsRegards,
EricZ
