Orbi WiFi 7 RBE973
Reply
netgear poe switch 8 port managed or Unmanaged
rick_h1
I would like to setup easy to maintain PoE 8 port the switch will have three access points and in the next few months two ip cameras. So do not know if it would be best to go with managed or unmanaged switch. any help would be appreciated.
Message 1 of 3
Guru
Re: netgear poe switch 8 port managed or Unmanaged
Are you planning on getting AP's the use central management? Or using vlans or anything else for the switches?
If your new to networking or unexperienced, I usually advise people to keep it simple and stick with unmanaged. .
but if your more experienced or wanting to get into managed switches, then its not a bad idea to try managed.
Message 2 of 3
rick_h1
Thanks info I have never setup APs. I need keep simple so look like a unmanaged would be best maybe the GS308PP
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 400 views
  • 0 kudos
  • 2 in conversation
Announcements
