× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Could Aircard 754s be used in T-mobile?
Jamessu
Follower
Hi, just eagerly want to know if Aircard 754s could support band12 which supported by T-mobile? I want to move it to T-mobile. Could I?
Any thought , please let me know.
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Could Aircard 754s be used in T-mobile?
Hello Jammessu
I believe you would have to get the device unlocked in order to use other SIM cards in the device so you may want to contact ATT to see if they will allow you to unlock the device in order to use other GSM SIM cards.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5113 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
