× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
LB1120 antenna overkill?
rramse
    Okay, first of all, I don't have any complaints about the Netgear internal antenna performance.  It works okay inside one house but in another house I need to run an external antenna because of cell tower obstructions not distance.  Two AT&T towers are located 1.5 and 4 miles away.
    My question is: are there any FCC restrictions against using a 2x24dBi parabolic antenna with the LB1120 power output?  LTE-Outdoor-Grid-Antenna
    I apologize if this question is sensitive, but I need to use 25ft of flexible RG58 and still get a good signal with an all metal antenna in 117 degrees of heat.
Message 1 of 4
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: LB1120 antenna overkill?
Hi rramse,
We received a feedback from the team. It would be best to check with FCC and Local Government regarding regulations when it comes to using of these type of antennas. We cannot really answer on behalf of FCC.
Blanca
Community Team
Message 3 of 4
All Replies
Blanca_O
NETGEAR Moderator
Hi rramse,
Welcome to NETGEAR Community!
Let me check this with the team. We'll get back to you.
Blanca
Community Team
Message 2 of 4
Blanca_O
NETGEAR Moderator
Hi rramse,
Blanca
Community Team
Message 3 of 4
rramse
Thank you for taking the time to check with your team and supply a response.  Not all manufacturers are as courteous to their customers as Netgear.  However, I still need to know the transmitting power output of the LB1120.  It's not listed anywhere I can find.
Maximum Power from Intentional Radiator *1
Maximum Antenna Gain (dBi)
EIRP (dBm) *3
EIRP (watts) *3
30dBm or 1 watt
6
36
4
29dBm or 800mW
9
38
6.3
28dBm or 630mW
12
40
10
27dBm or 500mW
15
42
16
26dBm or 400mW
18
44
25
25dBm or 316mW
21
46
39.8
24dBm or 250mW
24
48
63
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3714 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
