- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
LB2120 - Keeps switching between 4G and Broadband
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: LB2120 - Keeps switching between 4G and Broadband
Hi @blackeyes
Welcome to NETGEAR Community!
Have you tried resetting LB2120?
What is the current firmware version of LB2120?
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Blanca_O,
Thanks for your reply. I have already tried to reset the device to factory settings. The firmware version I have is M18QW_v07.05.170721 and when checking for updates, it says that there is no update available at this time. However the problem persists. One thing I have noted, if that helps, is that the mobile connection tends to drop from time to time. And the weird thing is that when it happens, I can still see typically 3 signal strength LEDs lit up on the device. So the connection shouldn't be down at that time, should it? Also, FYI, following those problems, I have added an external antenna now giving me RSRP around -80 to -105 and quality around 43 to 52 in 4G, depending on the weather. But that antenna did not improve stability in any way.
Do you have any other suggestion?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@MyFedLoan wrote:
I seem to have similar problem with my unit. fw shows the same 170721 although it was just recently updated. There's 1-3mb data usage every night, which costs me an euro per day. DSL log shows no dropouts. Elisa provides both DSL and cellular connection for me here in Finland. I've left the settings mostly in default so it works as an router, auto connects except when roaming and has only one device a smart home hub attached. Has worked very well when the DSL was suffering actual dropouts so these went unnoticed. Hw version 08. I bought this second hand on eBay as netgear Lb2120-100pes and paid 132 EUR shipping included. I have to get some lite account so will lose 4G unless there is some solution. I even bought an external antenna.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
FYI, my modem has been in bridge mode in between a DSL modem and another router. And I still have the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The new firmware version:
For LB2120-100AUS, LB2120-100EUS and LB2120-100PES, firmware version is NTG9X07C_13.05.04.00
And for LB2120-100NAS, firmware version is NTG9X07C_12.09.05.29
LB2120 (all SKUs) release notes:
New Features and Enhancements:
Added Keepalive settings to prevent the device from losing data connection due to idle timeout
Updated AutoAPN database to version 01.20
Bug Fixes:
Fixed security issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same issue. I received over 110 SMS alerts today where the LB2120 said it was failing over to LTE and then switching back. The cable modem connection was fine all the time, though. I rebooted the device and it has seemed ok for 30 minutes at least.
I'd prefer it if I didn't have to reboot the device as the LB2120 is supposed to be a network resiliance device so I would appreciate an update on what is casuing the issue for us and whether/when the software will be fixed. I'm happy to try changing a setting as a temporary workaround.
Thanks, Chris
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @chris12
May we please know the device SKU (e.g. LB2120-100NAS)? This can be checked on the box of the product or on the barcode label
Kindly check if you device has the latest firmware. Here's the firmware version per SKU:
- LB2120-100AUS, LB2120-100EUS and LB2120-100PES : NTG9X07C_13.05.04.00
- LB2120-100NAS : NTG9X07C_12.09.05.29
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the report. We have been investigating the issue for a while. We may need your help to collect some logs and help us verify the fixes later. Would you like to help us on these?
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Chris,
You can log in to WebUI to disable SMS notification for failover faeture as a workaround for now.
Sorry for the inconvenience.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
