× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Mr1100 sim not installed
Eldridger
Follower
I have a nighthawk m1 Hotspot device that has worked perfectly with cricket wireless. Recently I had issues with cricket and I removed the sim to put it in another device to check something. Now when I put the sim back into the nighthawk it is not picking it up. I verified that the sim works perfectly fine. Is there anything else I can do?
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 2
Blanca_O
NETGEAR Moderator
Re: Mr1100 sim not installed
Hi Eldridger,
Welcome to NETGEAR Community!
Kindly ensure that the SIM card is installed/inserted correctly in the MR1100.
Have you tried factory resetting the device? If not, please do so and check the connection.
Blanca
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2772 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
