YousefJ's avatar
YousefJ
Netgear Nighthawk M1 Charging Issues
Hello, so I’ve been using the NETGEAR Nighthawk M1 MR1100 Mobile Router for a while now. And I noticed a little issue with the charging, whenever I leave it charging overnight (while it’s at 13% of charge) and check back in the morning, it doesn’t charge as fast meaning it will be at about 24% after a day of charging. And this really annoys me because I always take my Mobile Router with me whenever I go outside, and it always runs out of battery because of this issue.
Before you ask me these:
1- I cleaned the Gold contacts both on the battery and the device.
2- I soft restarted the device.
3- I took out the battery out of the device and waited for over 30 seconds.
4- The cable is not damaged nor the battery or the device it self. (I doubled checked).
  • plemans's avatar
    are you using the officially supplied charger?  I couldn't find the specific power requirements but I'd check the power supply to make sure its giving the MR1100 enough amperage to fully charge it.
    • YousefJ's avatar
      YousefJ
      Hello, Plemans. Yes, I think I am using the official charging adapter. The Type is: B07LF. Input is: 100-240V ~ 50/60 HZ. Output is: 5.0 V — 2.0 A. Would that be enough power for it to charge properly? By the way, keep in mind that this happened pretty recently, not when I first bought the router. The first time I bought the router did not have this charging issue.
      • plemans's avatar
        My bet would either be the charger going bad or battery going bad.
        1. how long have you had it?Lithium has an expected shelf/usage life like a phone.
        2. Do you have any other chargers you could try that at least hit that charging specs?
        3. Have you changed cables recently? a bad cable could reduce power supplied. Or do you have a backup cable you could try to charge with?
