- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Next Generation Mobile HotSpot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, Good day
First i would like apologize in advance if i put that topic in wrong section.
the topic is about where mobile hotpot will be and what the available options in the market to improve the current models of Netgear.
as the latest model of mobile hotspot released in CES 2020 is Netgear M5
it hold outstanding capabilities but as others announced products exceeds the Netgear M5 standards and Netgear should response with something that takes steps ahead of the competitors.
current Netgear m5 uses
Qualcomm X55 as modern chip
Wifi AX1800 Radio tech
with built-in touch screen
and all day battery
the question is how we can improve that model and revolutionize the current standards
in my point of view, we should do the following
for the next model and revolotioize All in one hotspot
1- Use of the Qualcomm x60
benefits of using
(A)- mmWave-sub6 aggregation, extensive carrier aggregation and dynamic spectrum sharing, allowing tremendous operator flexibility to deploy unprecedented peak speeds with available spectrum resources.
(B)- Snapdragon X60 offers extensive deployment options such as mmW-sub6 aggregation, sub-6 carrier aggregation across TDD and FDD, Dynamic Spectrum Sharing
(C)- Better power efficiency compared to the X55
(D)- Supports any key 5G band, mode or combination
2- Elimination of the touchscreen and convert to one button wake and sleep
screen to view monitors like necessary info
connected devices , battery status , SSID and password ( can be hidden ) count of SMS and data usage
benefits of emanation of touch-screen
(A)- Reduce battery consumption
(b)- Eliminate unnecessary touches and cause of unintended change of settings
(c)- Make room for other part improvements
(d)- Improves the durability as the need to hold the router will be less and adjustments will be done using smartphone if required.
Note: settings can be changed in the Netgear application as modern routers uses that method and this method is more effective then changing settings on the screen of the router as the display small compared to the smartphones , more settings can be viewed and changed with authorized users only which improves security.
3- use of AX6000 and of AX1800 in together
will take mobile Hotspot to next step as AX1800 is high efficient and the AX6000 high performance but consumes high power
the solution is systematic way to switch between these radios
in battery usage AX1800 will be used
in Power sourced AX6000 will be used
that method will make the Next-generation 5G router take the lead
by doing the following ideas the next model will be a future-proof Hotspot.
i believe that how All in one Hotspot should be.
i hope that these ideas will be beneficial and took in consideration
Sorry for my bad English
Regards and Wishes.
Salem Alkandari
