× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M1 everyday plugged in?
Shotgunmiss
Can I use the Nighthawk M1 as an everyday whole house internet? If it’s plugged in all the time would there be a fire hazard with the battery? I’m assuming when you plug in the unit, it also charges the battery? Any safety issues I should consider?
Message 1 of 5
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: Nighthawk M1 everyday plugged in?
Hi @Shotgunmiss
If you plan to run the device 24/7, we suggest you to power the device with the PA only without inserting battery. This way, it will avoid the battery from getting hot and impacting the device's performance.
Blanca
Community Team
Message 4 of 5
All Replies
Guru
I didn't use that specific device but I had a different netgear hotspot used as 24/7 internet for a while. It worked well and was constantly powered on.
Message 2 of 5
Oxygene
Apprentice
Hi, just use without a battery! But use an original cable and a charger...
Message 3 of 5
Blanca_O
NETGEAR Moderator
Hi @Shotgunmiss
Blanca
Community Team
Message 4 of 5
Shotgunmiss
Thank you everyone
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3613 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
