- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Nighthawk M2 (MR2100) constant reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk M2 (MR2100) constant reboot
Sven P,
Thank you for your post. I can't download or access the Netgear app on my desktop computer - only on my mobile phone and Samsung tablet. This is in fact how the Telstra shop advised me to access the app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Jinall
Open a browser - and write http://m.home and hit enter
Take a look on your Quick Start instructions you received in the box.
Go to Set up the device and item 2 and follow instructions.
You do not change ETHERNET STANDBY option in the mobile ap.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sven P,
Many thanks for the advice. Seems to be working well at the moment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So now my M2 doesn't stay connected to devices. ie. when I come home and start up my laptop, it doesnt connect to the laptop, and when I look for the network, its not there. So I go and wake up the machine and it appears again! Frustrating!!!!!!! Why is it doing this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Wellington78
Make sure you have....
Global Wireless Setting
Disabled.
and
ETHERNET STANDBY
Disabled
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
Just an update for you.
My M2 has now been running since latest firmware update.
It did a freeze once, but I think that was my own fault.
How is your experience. I think Netgear should be updated if we are all happy
- Mark as New
- Bookmark
- Subscribe
- Permalink
like many constant reboot ... had to disable wifi to download the firmware ... firmware download was 5 times the speed once wifi disabled ..
now all the screens on 192.168.1.1 are data less... some basid info though 4 devices connected it says none
no data on down uploads and so much more .. all saying NA ..
tried contacting support .. tellls me my support expired on the 21/10/2019 to months into the future ... wont let me log in to my free 3 months support ..
the modem only arrived today from telstra
now i am not happy .. any one in support able to contact me
- Mark as New
- Bookmark
- Subscribe
- Permalink
Where in the settings can I set it to not go asleep?
I have look but cannont find it. Have also looked in the manual with out luck.
Regards
Henning
- Mark as New
- Bookmark
- Subscribe
- Permalink
Open a browser in a PC - and write http://m.home and hit enter
You can not change ETHERNET STANDBY option in the mobile ap.
The Ethernet standby regulate the time for asleep.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Henning
@HSvane wrote:Where in the settings can I set it to not go asleep?
Regards
Henning
are you Swedish?
See attached file for disable unit to go to sleep.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Sven
Thanks that helps.
No I am Danish.
Regards
Henning
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am also seeing this router 'hang' sporadically.
It will work for some time then just become unresponsive. Then decide to function again without intervention from anyone.
The behaviour seen is that the entire router stops responding, no traffic on the 4g link and no icmp response on the ethernet port.
I do have wifi on and when in this state I can connect to the device with the app. But in nearly every case if I then try to reboot the device using the app on the phone it permanently hangs until a physical reset pulling power cable.
Battery is not in, aerial connected to boost signal.
I have tried to find out how we can review logs on this device but not got anyway. There seems to be a dumbing down of the interface to the point that debugging a problem is almost impossibe. Anyone any idea how to get to see any logs?
- « Previous
- Next »
