× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk MR2100 M2 - Firmware no longer updating
Justin_Smith
Initiate
Hi,
My MR2100 last checked for a firmware update on 5/11/19 and is currently on NTGX24_10.16.03.00
When I press the "check for update" it just sits "checking" for ever and never completes.
I have powered down and restarted but it is no different, device details says:-
Nighthawk M2
Hardware Version1.0
Firmware VersionNTGX24_10.16.03.00
Modem VersionSDX24_10.24.00.00
GUI VersionMR2100-100EUS_04.02.124.00
PRI Version03.02
Firmware Build Date2019/08/02
Can anyone help?
Model: MR2100|Mobiler Router Nighthawk M2
Message 1 of 36
Accepted Solutions
btromsdorf
Tutor
Betreff: Nighthawk MR2100 M2 - Firmware no longer updating
THX John - good hint!
I tried updating when Data Offloading was on LAN so NTP would go thru... and that worked!
THX
BJ
Message 23 of 36
All Replies
JohnPeng
NETGEAR Expert
Re: Nighthawk MR2100 M2 - Firmware no longer updating
Please advise your country and carrier you are using.
Thanks
Message 2 of 36
Justin_Smith
Initiate
I am in the UK and it's an EE sim in there 🙂
Message 3 of 36
JohnPeng
NETGEAR Expert
It has been confirmed by one of EE UK customers that after he switch to another network, his device can be upgraded successfully.
We are working with EE UK to resolve the issue.
Thanks
Message 4 of 36
SluckP2
I have the same problem in germany with the provider german telekom.
If I switch to Ethernet via offloading the update is greyed out.
Using the broadband will endlessly scan for a new firmware.
Best regards,
Nils
Message 5 of 36
SluckP2
Workaround:
The scan is working if the provider connection has been established and afterwards the offloading via Ethernet will be enabled.
Best regards,
Nils
Message 6 of 36
btromsdorf
Tutor
I have the exact same problem with Deutsche Telekom Germany... just hangs when Intranet to update.
Message 7 of 36
Blanca_O
NETGEAR Moderator
Hi @btromsdorf
I have sent you a message. Please check your inbox.
Blanca
Community Team
Message 8 of 36
Retired_Member
Not applicable
Hello Guys,
i have the same problem. Someone has a solution?
I come from Austria and this is my Model:
 Nighthawk M2
Hardwareversion: 1.0
Firmwareversion: NTGX24_10.16.03.00
Modemversion: SDX24_10.24.00.00
GUI-Version: MR2100-100EUS_04.02.124.00
PRI-Version: 03.02
Firmware-Erstellungsdatum: 2019/08/02
Best Regards,
hellraver
Message 9 of 36
Retired_Member
Not applicable
Problem solved. I have reset the M2 to factory settings. Then an update was found and successfully downloaded and installed 🙂
Message 10 of 36
btromsdorf
Tutor
Lucky you 🙂 Firmware reset didn't work for me.
Message 11 of 36
Retired_Member
Not applicable
After the firmware reset, if you checked for a new update, the router was in the original settings?
Message 12 of 36
btromsdorf
Tutor
yes.. full reset... then configured again.. still indefinite loop looking for updates.
Message 13 of 36
Retired_Member
Not applicable
No, no! Do not understand me. Do a full reset and do not configure it again but look for an update right away.
Message 14 of 36
btromsdorf
Tutor
ah.. got it. Will try 🙂
Message 15 of 36
Retired_Member
Not applicable
I will be looking forward to your feedback 🙂
Message 16 of 36
JohnPeng
NETGEAR Expert
Please provide the current FW and PRI versions on your device. You can find these info on the About page on LCD UI.
Thanks
John
Message 17 of 36
btromsdorf
Tutor
Unfortunately did not work for me.
Factory Reset ->  then I just set the language. ->skip the rest of setup ->try update ... infinite loop 😞
Message 18 of 36
btromsdorf
Tutor
Hi John,
I am on Firmware NTGX24_10.16.03.00   PRI Version 03.02
Hope that helps,
BJ
Message 19 of 36
JohnPeng
NETGEAR Expert
@btromsdorf wrote:
Hi John,
Hope that helps,
BJ
Please let me know the carrier you are using with the device.
Thanks
Message 20 of 36
btromsdorf
Tutor
@JohnPeng wrote:
@btromsdorf wrote:
Hi John,
Hope that helps,
BJ
Thanks
I am on Deutsche Telekom (in Germany)
THX,
BJ
Message 21 of 36
JohnPeng
NETGEAR Expert
Hi All,
On this FW upgrade issue, we noticed that some carriers blocked the NTP port used by the device to get the correct system time. This will prevent the devices from connecting to our FW update server. We are working on a solution for this.
Please also help to confirm whether your devices show the correct time on LCD when the device can't connect to our upgrade server.
Thanks
John
Message 22 of 36
btromsdorf
Tutor
THX
BJ
Message 23 of 36
JohnPeng
NETGEAR Expert
THX
BJ
Hi BJ,
Thank you very much for the workaround. We will advise the customers on this while we are working on an official fix on the issue.
Regards
John
Message 24 of 36
deftly
I had success using the ios app to update modem firmware while connected to the M2.
Using Telstra version of M2. Despite being unable to due to being "over allowance" ( even though it's a SIM-share device) it worked.
Hope this helps.
Message 25 of 36
Top Contributors
Discussion stats
  • 35 replies
  • 9787 views
  • 4 kudos
  • 13 in conversation
Announcements
Orbi WiFi 7
