Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS748T trunking togethers
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2007-08-20
05:46 PM
2007-08-20
05:46 PM
We have a pair of GS748T. One is recent the other is about 2 years old.
From what I have read it should be possible to port trunk our 2 xserves to each of these switches. But is it also possible to have port trunks set up between the two switches effectively creating a dual channel between them?
Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2007-08-23
10:37 PM
2007-08-23
10:37 PM
Re: GS748T trunking togethers
Both Switches are running the latest firmware.
I have tried to trunk two ethernet connections from my Intel xServe (10.4.10) to the switch but it does not work.
Has anyone gotten these damn switches to trunk successfully?
Message 2 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2007-08-24
05:20 AM
2007-08-24
05:20 AM
Link Aggregation
Trunking
I take it you realise that your two posts deal with different issues.
Yes - you can configure trunks between the switches - I haven't personally done it with that model - but it shouldn't require more than just checking a few boxes in the web interface (it might be called LAG - Link Aggregate Group - rather than trunk).
I've never worked with the xServe so I can't comment on what's required, but in a Microsoft environment whether or not this can be done is dependent more on the network cards and their associated drivers than anything else.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Trunking
Message 3 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2007-08-24
08:57 AM
2007-08-24
08:57 AM
spinifex wrote: Both Switches are running the latest firmware.
This has been discussed at length on the macos-x-server mailing list. See, for example, this response from the archives:
http://lists.apple.com/archives/macos-x-server/2007/Mar/msg00405.html
You can search the macos-x-server list archives here:
http://search.lists.apple.com/
Russ
Message 4 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2007-08-26
10:43 PM
2007-08-26
10:43 PM
Thanks for the replies. Originally I just wanted to trunk the switches together (which I still haven't tried) but the more pressing issue was increasing bandwidth for my users on the xServe. From the sounds of it this is a problem with the intel xServes so the switches are off the hook.
I'll keep an eye on that mailing list.
Message 5 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2007-08-28
11:03 PM
2007-08-28
11:03 PM
Ok the Lights Out Management feature of the xServe is not being used so Port Trunking should work. I have confirmed my software settings as correct and by all accounts the problem is with the switch.
I have been told to set one of the trunk ports as an LACP master port but there is no option anywhere in the Netgear admin software to designate a master port.
Does anyone have any ideas?
Message 6 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2007-08-28
11:20 PM
2007-08-28
11:20 PM
Can anyone tell me if they have successfully used LACP to connect a server to a Netgear Smart Switch. From the sounds of the manual the port trunking is only supported to connect two switches together.
The section in the manual on Trunking lists:
“Port Trunking (otherwise known as Port Aggregation) enables multiple links between switches”
this is correct as a “Trunk” is generally a proprietary method for increasing the bandwidth between 2 switches from the same vendor.
It cannot be used to connect to switches of different brands, or to hosts running link aggregation.
LACP-based 802.3ad link aggregation is generally only found in high-end switches and has a number of different options, such as LACP mode or Static mode, setting Master ports, etc.
Message 7 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-07-27
08:24 AM
2011-07-27
08:24 AM
fyi peeps, trunk ports are used to transfer vlan data from one switch to another switch or trunk capable devices such as wireless APs.
therefore, if Switch A port 1 is set to trunk for Vlan 3.. and port 20 is set to Untagged or otherwise known to set to VLAN 3, then if port 1 of switch A is connected to port 1 of Switch B that is set with the same config of Vlan 3 (tagged or trunk), then VLAN 3 data will be transfered from Switch A to Switch B.
so a PC connected to port 20 in SwitchA, can deliver data to another PC connected to port..24 in SwitchB if the port 24 in switch B is configured as Untagged VLAN3.
Message 8 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-07-27
03:54 PM
2011-07-27
03:54 PM
bridgesint wrote: fyi peeps, trunk ports are used to transfer vlan data from one switch to another switch or trunk capable devices such as wireless APs.
FYI person - whilst that is one of application of trunking, there are others.
Message 9 of 9
Announcements
To post a question to this Ask Me Anything AMA board, click here or the "Create A New Discussion" button and be sure it's written in the form of a question. Click the Pinned instructions thread to lean more.
