Orbi WiFi 7 RBE973
Reply
Nighthawk ax6000 not working with xfinity stream
DayHawk96
Upgraded to the nighthawk cax80 to get rid of the rented router I had, now xfinity stream won't work over this router/modem?
They have xfinity on the box and is listed on their suggested site. Super frustrating...
Message 1 of 8
Accepted Solutions
DayHawk96
Re: Nighthawk ax6000 not working with xfinity stream
The problem was netgear armor. It was blocking the stream from xfinity for whatever reason.
Hopefully they can fix that feature because I liked the security...
Message 4 of 8
All Replies
Guru
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Message 2 of 8
Guru
Its only xfinity stream not working?
Are you streaming it using their flex box or what are you using to stream with it?
what actually happens when you try to use it?
Message 3 of 8
DayHawk96
Message 4 of 8
Guru
So with Armor disabled, the stream is now working?
Message 5 of 8
DayHawk96
Yup as soon as I turned off Armor the stream started right away. It only affected xfinity stream all the rest of my streaming services worked just fine... Hopefully they can fix this issue.
Message 6 of 8
Guru
Something I would make contact with NG support about to let them know.
Message 7 of 8
Guru
You could go into the armor setup and see if its a specific url thats being blocked.
https://kb.netgear.com/000061715/How-do-I-unblock-URLS-in-NETGEAR-Armor
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3287 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
