- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Armor impacting xbox speeds and Packet Loss
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello all,
Have an xbox One hard wired into a switch. Switch is connected to Orbi then to cable modem acting as a bridge. Before these issues, I consistently received speeds of 350ms down and 25m up. I recently added the Orbi Armor product and all of a sudden my speeds are running no more than 115m down and 12m up with 1-3% packet loss. Almost as if my speeds were cut in half. When I run speed tests on my other devices, I am getting good speeds in the 350 range. Speed issues appear only on the xbox. Here is what I have done so far.
- Plugged xbox directly into Orbi - Same Result
- Set Static IP on Xbox - Same Result
- Placed static IP in DMZ - Same result
- Used different DNS IPs - Same Result
- Power cycled Orbi and cable modem - Same result
- Changed Cat 6 cables - Same result
- Tried wifi - no improvement
Any additional help will be greatly appreciated. Not sure what else I can do but to scrap the Armor product and hard reset the Orbi. THank you in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi Armor impacting xbox speeds and Packet Loss
Factory reset the RBR and this time setup from scratch and do not enable Armor. Check speeds.
Others have posted various issues using Armor. Would not be good for gaming.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router SXK30(v.122) and R8500(v.158) Router Mode and Wired Backhaul | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I was able to hard reset the orbi and my speeds are back to nornal. Thank you! However, I am still having packet loss issues on the xbox. Latency is running at about 62-67ms which is good but a lil higher than friends I have asked to test their xbox speeds. After the hard reset I am still running a 1-3% packet loss.
I will have to reach back to Netgar/ Bitdefender for a possible refund on the Armor product if this is not going to work.
Thanks again for the help and any additional guidance will be apreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi @kcor, thanks for responding. Do you still have Armor enabled? If yes, as a way to isolate what's causing the issue, please try temporarily disabling it and check if there is any improvement on the latency (ping). If the issue will persist while Armor is disabled, you can try and check the modem. You can bypass the router and connect straight to your ISP's modem and check if it is still the same.
Dexter
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Armor is disabled. I am going to go straight to the ISP modem and let you know how that works out. First, I have to hard reset that device again as I have it setup as a bridge. Will reach back shortly. Thank you again for all the guidance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ok, I went ahead and hard reset the ISP modem and ran some tests. Was still getting 1-3% packet loss. I reached out to ISP and they were looking into. Woke up this AM and ran about 20 tests and only 1 test had a .34% packet loss. So I am thinking I am all set now as chalking up the packet loss as a ISP issue. Thank you for the help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
