Orbi WiFi 7 RBE973
Reply
Unable to activate Netgear armor
wvwavere
Initiate
I recently purchased a Orbi 852 set with Armor and Parental control subscriptions.
Activating parental control worked without any issues, but when I attempt to activate Armor from the android app it only gives the option to activate a trial subscription.
If I attempt to activate the trial subscription I get an error saying "failed to subscribe"
When I log in to my.netgear.com I can see both subscriptions for Armor and parental controls.
When I log in to armor.netgear.com it shows I have no subscriptions.
I logged a case with bitdefender who had a look and advised I should talk to netgear as they can't see anything for my account on their side.
I logged a support case with netgear that has now been ongoing for more than a week and all I keep getting is do a factory reset, uninstall the mobile app and reinstall it - which I have done a few times now but still no luck in getting my subscription activated.
Any ideas?
Message 1 of 6
Accepted Solutions
wvwavere
Initiate
Re: Unable to activate Netgear armor
Installed a beta firmware version provided by support and another factory reset and the issue is now resolved.
Message 5 of 6
All Replies
Guru
Sadly it usually does need to go through support.
Maybe @DarrenM can help escalate it.
Message 2 of 6
Blanca_O
NETGEAR Moderator
Hi @wvwavere
System shows that your case is already escalated to the next level of support team. We have notified support to follow up on your case and they should be contacting you as soon as possible to discuss the next action.
Blanca
Community Team
Message 3 of 6
Guru
Any progress on this?
Any ideas?
Message 4 of 6
wvwavere
Initiate
Message 5 of 6
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2905 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi 770 Series
