rmen55
Jan 24, 2020Follower
readynas 258x8
I would like to connect my readynas to a single pc that is not on a network. can i connect it thru a usb port?
1 Reply
No, you can't
Consider using an diect network connection, most simple one Ethernet cable, and manually conigure an IP subnet with two different addresses on the PC and the RN interface.
