Orbi WiFi 7 RBE973
Reply
Blocked Devices on ORBI RBR20
ShawnaShaffer
Follower
I paused wifi on a few devices for the evening.  Next morning, turned them all back on, but now none of those devices are able to connect to the wifi, instead the devices receive a message that the server is blocked.  Any guidance?  I've rebooted the devices, rebooted the router and orbi systems.  Nothing is working to unlock them.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
CrimpOn
Guru
Re: Blocked Devices on ORBI RBR20
Caveat: I know nothing about Parental Controls. I am only on this forum because the Orbi "app" seems to think I started configuring them and won't let me "just say no."
Could you do a quick check on the Orbi web interface of the Attached Devices page?
Is Access Control enabled or not enabled?
I almost never use the Orbi "app", but one time after opening it to check something, I found that Access Control had been enabled on my Orbi and at least one device was not "Blocked".  Quickly turned Access Control to OFF (while swearing. computers understand threats.)
Problem went away.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1783 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
