Orbi WiFi 7 RBE973
Cant unlock premium SPC future on RBR50
Stege
Tutor
Hallo
I can´t unlock the premium future of SPC (Mytime) on my RBR50 router
My trial worked perfect but the trial period is closed and when i tap the unlock premium ind the android app there  are only showing 3 blue icons and nu text.
When i login on the router directly the SPC area are missing.
RBR50 firmware : V2.7.4.24
With regards
Morten
Message 1 of 29
Guru
Re: Cant unlock premium SPC future on RBR50
Message 2 of 29
Stege
Tutor
All should be okay
Country supportet - Denmark
Latest firmware - v2.7.4.24
Latest orbi app
Message 3 of 29
Stege
Tutor
Anybody ???
Message 4 of 29
Guru
Have you powered OFF the ISP modem, router and your mobile device for 1 minute then back ON and see if the NH Circle app can connect to the router?
Message 5 of 29
Stege
Tutor
Hey
The orbi rbr50 router is connected to provider "FASTSPEED" in Denmark with a Sagem Fast 3890V3 for coax signal
I have tryed to turn of power on the Orbi royter and the Sagem unit
I have also tryed to start from scratch
Nothing has fixet it.
Message 6 of 29
Guru
Your ISP modem has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-...
Message 7 of 29
Stege
Tutor
Hey
Router is a sagemcom coax cable modem and router
Isp is 'fastspeed' in denmark
Sagemcom is in Bridge mode and wifi off
Orbi router rbr50 is factory reset and latest firmware installed.
Orbi has static ip assigned.
Still not working.
Message 8 of 29
Guru
Check to be sure SPC is supported in your region:
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/Smart-Parental-Controls-Help-and-Inform...
Also by your screen capture it says SPC is Expired so you may need to subscribe to it again.
If you have continued problems, contact NG support for additional help and information.
Message 9 of 29
Jwouter
Hi ,
Was this problem fixed for you if so how , as I have the same issue
Jwouter
Message 10 of 29
Stege
Tutor
Nope still not working.
Message 11 of 29
schumaku
Guru
What about @FURRYe38's valid input?
Message 12 of 29
Jwouter
that’s exactly what I and the OP tried to do, after the trail expired unlock  / purchase  the service… so yes it will show its expired….
Message 13 of 29
Stege
Tutor
When i try to reactivate its say that no plan i is available
Message 14 of 29
Stege
Tutor
The trial was ok but after expire it cant be activated again
Message 15 of 29
Jwouter
I have a plan available, however i can’t pay there is a green tick box to accept terms and conditions that I can’t seem to select...... logged a call 2 weeks ago but nothing from netgear.
Message 16 of 29
Stege
Tutor
They must get it fixed asap
Message 17 of 29
Guru
Message 18 of 29
Jwouter
As said call is open with Netgear , called them multiple times.
so no Netgear has niet been very helpful
Message 19 of 29
KevinLiT
NETGEAR Moderator
Hello @Jwouter ,
Welcome to the NETGEAR Community!
Thank you for your post in regard to your issue with your SPC subscription.
Which application version do you currently have installed on your mobile device?
Best,
Kevin
Community Team
Message 20 of 29
Jwouter
hi,
version 2.20.1.12
j wouter
Message 21 of 29
Stege
Tutor
2.7.4.24
Message 22 of 29
Sulphate9402
Guide
Im having the same effin problem with my RBR850. Its not an issue with the firmware or router. Its a dang issue with the app software. The monkeys that coded it made the TOS checkbox/circle un tickable.
And since we cant accept the TOS, we cant click the purchase button. FIX THIS ASAP. How did this bug make it to production?
I've tried this on IOS And ANDROID and the same issue persists.
Message 23 of 29
Jwouter
Don’t think it’s the app , my money it’s that the issue is with our accounts ….
Message 24 of 29
Stege
Tutor
Something is wrong an a solution is needed ASAP 😡
Message 25 of 29
Top Contributors
Discussion stats
  • 28 replies
  • 5295 views
  • 4 kudos
  • 6 in conversation
Announcements
Orbi 770 Series
