Orbi WiFi 7 RBE973
Reply
MR60 Sattelite will not reset
lifer70
One of my Nighthawk mesh WiFi 6 MR60 routers has a steady flashing light. I cannot reset it or change the flashing light. The other Sattelite is working fine.
Message 1 of 4
lifer70
Re: MR60 Sattelite will not reset
White steady flashing light
Message 2 of 4
Guru
If you hardwire it into the router, are you able to see/access it?
Also, when its hardwired, check the firmware version its on.
What version is on the router?
and on the satellite?
Message 3 of 4
Bruce49
Tutor
I had the same problem on 2/12/22. I had to do a firmwear update to get the MR60 working again. Fortunately, it was still under warranty and I was able to get assistance from Netgear tech support. I don't think I could have done it without support.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1404 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
