NASNoob11
Jun 27, 2012Aspirant
How to 'print' the HCL?
I will suppose I have a glitch with FF 13.0.1, but, each time I try to print a selected HCL list, all I seem to print (3 pages) is the opening text, my choice, the top several entries (big drives!), and, the bottom text of the 'list' (?frame?). :?
Is it me or the HCL list logic?
Long ago (2008) the entire HCL would print out.
Would like to do some HCL choice research prior to a buy of 4 hard drives.
- StephenBGuru - Experienced Usertry right-clicking in the middle of the list and selecting "print frame"
- HERBIEOAspirantI just tried a print preview and it looked ok.
- StephenBGuru - Experienced UserI tried printing to PDF with FF 13.0.1 and got the same thing NASNoob did. Right-clicking on the list and selecting "print frame" solved it.
- NASNoob11Aspirant
StephenB wrote: try right-clicking in the middle of the list and selecting "print frame"
StephenB,
Thank you. Yes, this trick worked perfectly. And, I learned a new XP sub-menu also! :)
Have the full list and can continue research/choice for drives. - ReadySECUREApprenticeI am glad you were able to get that printed out, just make sure to check back for changes as this is a live list that could be updated at any time.
- HERBIEOAspirantThere is no option to print frame in chrome or IE8 in the context menu.
- chirpaLuminaryYou can access the page directly at http://www.readynas.com/app/hcl_disk outside of iframes.
- HERBIEOAspirantNice thx chirpa.
- PapaBear1ApprenticeIn deed, that is good to know. I have book marked that link.
