betstu's avatar
betstu
NV+ and Seagate ST2000DM001-1CH164 failure?
I had 3 of my 4-year old ST31500341AS fail over the past months and had to replace the last one with another model as the 315s are no longer available. Note, that the last ST315 failed without warning or major errors - the ReadyNAS would not reboot (no drive light / act on - just the power light slow-blinking). It did reboot with USB boot and Disk 1 removed.
The ST2000DM001 seemed to have initialize properly when first inserted and the RAID synced. However, the performance seemed to be sluggish and there were some errors in the log. Less than a day later ReadyNAS reported the drive as failed.
I have taken the drive and run the battery of SeaTools tests on it and it passed with flying colors. I have reinserted the drive and it initialized and synced OK again, but the ReadyNAS would not boot afterwards again. It booted as before with USB and Disk 1 removed.
Following are my logs from trying the whole process once again. Could this be caused by:
1) The drive is actually defective? Unlikely, as it is a new replacement, but will check - should have a few more of these coming shortly
2) The drive is not compatible with ReadyNAS despite featuring on the drive compatibility list. If so, can anyone think of any workarounds?
3) The ReadyNAS is developing a hardware problem with SATA communication. Any troubleshooting steps?
I will appreciate any ideas.
Matt
Feb  8 11:33:03 data kernel: LPCH_ACTIVE still on: 10
Feb 8 11:33:03 data kernel: 2req = 1 89071650,00000000,00000000,00000000 1
Feb 8 11:44:11 data exiting on signal 15
Feb 8 13:32:07 data syslogd 1.4.1#10: restart.
Feb 8 13:32:08 data kernel: klogd 1.4.1#10, log source = /proc/kmsg started.
Feb 8 13:32:08 data kernel: Linux version 2.6.17.14ReadyNAS (root@calzone) (gcc version 3.3.5 (Infrant 3.3.5-1)) #1 Wed Jun 20 20:08:20 PDT 2012
Feb 8 13:32:08 data kernel: You system is PZERO.
Feb 8 13:32:08 data kernel: ASIC=IT3107
Feb 8 13:32:08 data kernel: zlist 0 802f115c
Feb 8 13:32:08 data kernel: zone 802f0f14, name Normal
Feb 8 13:32:08 data kernel: zlist 1 802f1170
Feb 8 13:32:08 data kernel: zone 802f0ccc, name DMA
Feb 8 13:32:08 data kernel: zlist 2 802f1184
Feb 8 13:32:08 data kernel: Built 1 zonelists
Feb 8 13:32:08 data kernel: Kernel command line: root=/dev/ram0 init=/linuxrc rw raid=noautodetect profile=2
Feb 8 13:32:08 data kernel: kernel profiling enabled (shift: 2)
Feb 8 13:32:08 data kernel: PID hash table entries: 4096 (order: 12, 16384 bytes)
Feb 8 13:32:08 data kernel: Dentry cache hash table entries: 131072 (order: 5, 524288 bytes)
Feb 8 13:32:08 data kernel: Inode-cache hash table entries: 65536 (order: 4, 262144 bytes)
Feb 8 13:32:08 data kernel: Memory: 1010048k/1048576k available (2592k kernel code, 38016k reserved, 656k data, 96k init, 0k highmem)
Feb 8 13:32:08 data kernel: init_mm.pgd bf0ff000
Feb 8 13:32:08 data kernel: Mount-cache hash table entries: 2048
Feb 8 13:32:08 data kernel: checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Feb 8 13:32:08 data kernel: Freeing initrd memory: 16384k freed
Feb 8 13:32:08 data kernel: NET: Registered protocol family 16
Feb 8 13:32:08 data kernel: usbcore: registered new driver usbfs
Feb 8 13:32:08 data kernel: usbcore: registered new driver hub
Feb 8 13:32:08 data kernel: NET: Registered protocol family 2
Feb 8 13:32:08 data kernel: IP route cache hash table entries: 8192 (order: 1, 32768 bytes)
Feb 8 13:32:08 data kernel: TCP established hash table entries: 32768 (order: 3, 131072 bytes)
Feb 8 13:32:08 data kernel: TCP bind hash table entries: 16384 (order: 2, 65536 bytes)
Feb 8 13:32:08 data kernel: TCP: Hash tables configured (established 32768 bind 16384)
Feb 8 13:32:08 data kernel: TCP reno registered
Feb 8 13:32:08 data kernel: audit: initializing netlink socket (disabled)
Feb 8 13:32:08 data kernel: audit(1070280003.210:1): initialized
Feb 8 13:32:08 data kernel: VFS: Disk quotas dquot_6.5.1
Feb 8 13:32:08 data kernel: Dquot-cache hash table entries: 4096 (order 0, 16384 bytes)
Feb 8 13:32:08 data kernel: Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Feb 8 13:32:08 data kernel: Initializing Cryptographic API
Feb 8 13:32:08 data kernel: io scheduler noop registered
Feb 8 13:32:08 data kernel: io scheduler anticipatory registered
Feb 8 13:32:08 data kernel: io scheduler deadline registered
Feb 8 13:32:08 data kernel: io scheduler cfq registered (default)
Feb 8 13:32:08 data kernel: RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
Feb 8 13:32:08 data kernel: loop: loaded (max 8 devices)
Feb 8 13:32:08 data kernel: nbd: registered device at major 43
Feb 8 13:32:08 data kernel: tun: Universal TUN/TAP device driver, 1.6
Feb 8 13:32:08 data kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Feb 8 13:32:08 data kernel: md: raid0 personality registered for level 0
Feb 8 13:32:08 data kernel: md: raid1 personality registered for level 1
Feb 8 13:32:08 data kernel: md: raid5 personality registered for level 5
Feb 8 13:32:08 data kernel: md: raid4 personality registered for level 4
Feb 8 13:32:08 data kernel: xor engine => SPARC.
Feb 8 13:32:08 data kernel: device-mapper: 4.6.0-ioctl (2006-02-17) initialised: dm-devel@redhat.com
Feb 8 13:32:08 data kernel: Serial: Padre driver $Revision: 1.1.1.1 $ 2 ports
Feb 8 13:32:08 data kernel: ttyS0 at I/O 0x0 (irq = 7) is a padre uart
Feb 8 13:32:08 data kernel: ttyS1 at I/O 0x0 (irq = 8) is a padre uart
Feb 8 13:32:08 data kernel: oprofile: using timer interrupt.
Feb 8 13:32:08 data kernel: TCP bic registered
Feb 8 13:32:08 data kernel: NET: Registered protocol family 17
Feb 8 13:32:08 data kernel: NET: Registered protocol family 5
Feb 8 13:32:08 data kernel: 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
Feb 8 13:32:08 data kernel: All bugs added by David S. Miller <davem@redhat.com>
Feb 8 13:32:08 data kernel: md: Skipping autodetection of RAID arrays. (raid=noautodetect)
Feb 8 13:32:08 data kernel: RAMDISK: Compressed image found at block 0
Feb 8 13:32:08 data kernel: VFS: Mounted root (ext2 filesystem).
Feb 8 13:32:08 data kernel: Freeing unused kernel memory: 96k freed
Feb 8 13:32:08 data kernel: padre_i2c: module license 'Infrant Technologies, Inc.' taints kernel.
Feb 8 13:32:08 data kernel: padre_i2c: no version for "udiv" found: kernel tainted.
Feb 8 13:32:08 data kernel: TWSI Initialize
Feb 8 13:32:08 data kernel: Padre NSPIO setup: 80353394... No argv, go to default.
Feb 8 13:32:08 data kernel: raid5: xor select to PADRE_RXA.
Feb 8 13:32:08 data kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Feb 8 13:32:08 data kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Feb 8 13:32:08 data kernel: padre chip scan,token=1
Feb 8 13:32:08 data kernel: Scan the padre NSP IO hardware.
Feb 8 13:32:08 data kernel: Need memory for RTEngine 63680
Feb 8 13:32:08 data kernel: PIO mode on chan 7
Feb 8 13:32:08 data kernel: DMA mode on chan 0
Feb 8 13:32:08 data kernel: DMA mode on chan 1
Feb 8 13:32:08 data kernel: DMA mode on chan 2
Feb 8 13:32:08 data kernel: DMA mode on chan 3
Feb 8 13:32:08 data kernel: Padre IDE controller, sata start:1
Feb 8 13:32:08 data kernel: No TLER on ST31500341AS ^P\200
Feb 8 13:32:08 data kernel: hde: ST31500341AS (s/n:9VS0KPLE), ATA DISK drive (ATAEXT)
Feb 8 13:32:08 data kernel: hdg: ST31500341AS (s/n:9VS57MYW), ATA DISK drive (ATAEXT)
Feb 8 13:32:08 data kernel: hdi: ST31500341AS (s/n:9VS5A88X), ATA DISK drive (ATAEXT)
Feb 8 13:32:08 data kernel: ide1 at 0x200-0x207,0x208 on irq 32
Feb 8 13:32:08 data kernel: ide2 at 0x280-0x287,0x288 on irq 33
Feb 8 13:32:08 data kernel: ide3 at 0x300-0x307,0x308 on irq 34
Feb 8 13:32:08 data kernel: ide4 at 0x380-0x387,0x388 on irq 35
Feb 8 13:32:08 data kernel: Update NSPIO settings 80353394.
Feb 8 13:32:08 data kernel: hde: max request size: 512KiB
Feb 8 13:32:08 data kernel: hde: use capacity 2930277168 sectors (1500301 MB)
Feb 8 13:32:08 data kernel: Drive support hpa, still should not change max addr.
Feb 8 13:32:08 data kernel: hde: 2930256688 sectors (1500291 MB), CHS=65535/255/63
Feb 8 13:32:08 data kernel: hde: cache flushes supported
Feb 8 13:32:08 data kernel: hde: hde1 hde2 hde3 < hde5 hde6 >
Feb 8 13:32:08 data kernel: hdg: max request size: 512KiB
Feb 8 13:32:08 data kernel: hdg: use capacity 2930277168 sectors (1500301 MB)
Feb 8 13:32:08 data kernel: hdg: 2930256688 sectors (1500291 MB), CHS=65535/255/63
Feb 8 13:32:08 data kernel: hdg: cache flushes supported
Feb 8 13:32:08 data kernel: hdg: hdg1 hdg2 hdg3 < hdg5 hdg6 >
Feb 8 13:32:08 data kernel: hdi: max request size: 512KiB
Feb 8 13:32:08 data kernel: hdi: use capacity 2930277168 sectors (1500301 MB)
Feb 8 13:32:08 data kernel: hdi: 2930256688 sectors (1500291 MB), CHS=65535/255/63
Feb 8 13:32:08 data kernel: hdi: cache flushes supported
Feb 8 13:32:08 data kernel: hdi: unknown partition table
Feb 8 13:32:08 data kernel: Link to padre IO.
Feb 8 13:32:08 data kernel: RAID disks check:
Feb 8 13:32:08 data kernel: ALL = 33/34/56/0/0/0/0/0, 3
Feb 8 13:32:08 data kernel: IDE = 33/34/0/0/0/0/0/0, 2
Feb 8 13:32:08 data kernel: MD = 0/0/0/0/0/0/0/0, 0
Feb 8 13:32:08 data kernel: RAID rule check result: 0
Feb 8 13:32:08 data kernel: md: md driver 0.90.3 MAX_MD_DEVS=256, MD_SB_DISKS=27
Feb 8 13:32:08 data kernel: md: bitmap version 4.39
Feb 8 13:32:08 data kernel: Disk protected mark = 1
Feb 8 13:32:08 data kernel: x_raid_start: 1,current:0
Feb 8 13:32:08 data kernel: BDL_count= 0, fw=SN04, model=
Feb 8 13:32:08 data kernel: BDL_count= 1, fw=SN04, model=
Feb 8 13:32:08 data kernel: GOT MEMORY FOR DJ: 128*4k
Feb 8 13:32:08 data kernel: Drive hde SB at 2930263632(-sbs) CURRENT
Feb 8 13:32:08 data kernel: Drive hdg SB at 2930263632(-sbs) CURRENT
Feb 8 13:32:08 data kernel: Drive hdi SB at 2930263632(-sbs) CURRENT
Feb 8 13:32:08 data kernel: x_raid_start: 1,result:0
Feb 8 13:32:08 data kernel: Find PHY: 0
Feb 8 13:32:08 data kernel: Lookup PHY ID: 0x000f, 0x01
Feb 8 13:32:08 data kernel: P0 GPIO initialization... BOARDID=1
Feb 8 13:32:08 data kernel: Boot type/reason: normal/0/0
Feb 8 13:32:08 data kernel: Adjusting fan pwm........................
Feb 8 13:32:08 data kernel: Found LM75 at 0x48
Feb 8 13:32:08 data kernel: NAND device: Manufacture ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
Feb 8 13:32:08 data kernel: Samsung NAND flash rev C
Feb 8 13:32:08 data kernel: size of table 4096
Feb 8 13:32:08 data kernel: table is there 0x8
Feb 8 13:32:08 data kernel: total bad block 0
Feb 8 13:32:08 data kernel: Total bad block number 0
Feb 8 13:32:08 data kernel: retlen = 0x0200
Feb 8 13:32:08 data kernel: VPD checksum = 0x562d
Feb 8 13:32:08 data kernel: ECC is ON
Feb 8 13:32:08 data kernel: Creating 2 MTD partitions on "NAND 64MiB 3,3V 8-bit":
Feb 8 13:32:08 data kernel: 0x00000000-0x00100000 : "P0 flash partition 1"
Feb 8 13:32:08 data kernel: 0x00100000-0x04000000 : "P0 flash partition 2"
Feb 8 13:32:08 data kernel: NEON flash: probing 8-bit flash bus
Feb 8 13:32:08 data kernel: NEON flash: Found no Atmel device at location zero
Feb 8 13:32:08 data kernel: This board is not supported.
Feb 8 13:32:08 data kernel: You can use parm_extport=X module parm.
Feb 8 13:32:08 data kernel: ID=6013 on i2c_addr=1f
Feb 8 13:32:08 data kernel: GPIO2X=7c
Feb 8 13:32:08 data kernel: lcd:driver loaded
Feb 8 13:32:08 data kernel: X_RAID_START
Feb 8 13:32:08 data kernel: startstop XRAID command = start, flash_cache=0
Feb 8 13:32:08 data kernel: X_RAID clean shutdown indicator: 0x0.
Feb 8 13:32:08 data kernel: 0 0 3 3 3 0 0 0
Feb 8 13:32:08 data kernel: 0 0 0 0
Feb 8 13:32:08 data kernel: 0 0 1 1
Feb 8 13:32:08 data kernel: 0 1 0 1
Feb 8 13:32:08 data kernel: 0 1 1 0
Feb 8 13:32:08 data kernel: Update time for sb 1 = 0.
Feb 8 13:32:08 data kernel: Update time for sb 2 = 51142462.
Feb 8 13:32:08 data kernel: Update time for sb 3 = 51142462.
Feb 8 13:32:08 data kernel: Update time for sb 4 = 51142462.
Feb 8 13:32:08 data kernel: recent_ID = 2, select_ID=2, most_ID=3 right_mac=4
Feb 8 13:32:08 data kernel: Selected sb 2, ctime=51142462, id=a2014319.
Feb 8 13:32:08 data kernel: Use this image: 2
Feb 8 13:32:08 data kernel: VERSION/ID : SB=(V:0.1.0) ID=<a2014319.00000000.00000000.00000000> CT:51142462
Feb 8 13:32:08 data kernel: RAID_INFO : DISKS(TOTAL:4 RAID:4 PARITY:3 ONL:4 WRK:4 FAILED:0 SPARE:0 BASE:0)
Feb 8 13:32:08 data kernel: SZ:2930256688 UT:00000000 STATE:0 LUNS:2 EXTCMD:1 LSZ:2930256686
Feb 8 13:32:08 data kernel: LOGICAL_DRIVE : 0: B:0000000002 E:0004096000 R:1 O:1 I:1:000000000 DM:f
Feb 8 13:32:08 data kernel: LOGICAL_DRIVE : 1: B:0004096002 E:2926160686 R:4 O:1 I:1:000000000 DM:f
Feb 8 13:32:08 data kernel: PHYSICAL_DRIVE: 0: DISK<N:0/1,hdc(22,0),ID:0,PT:1,SZ:3907008688,ST: B:online>
Feb 8 13:32:08 data kernel: PHYSICAL_DRIVE: 1: DISK<N:1/2,hde(33,0),ID:1,PT:1,SZ:2930256688,ST: :online>
Feb 8 13:32:08 data kernel: PHYSICAL_DRIVE: 2: DISK<N:2/3,hdg(34,0),ID:2,PT:1,SZ:2930256688,ST: :online>
Feb 8 13:32:08 data kernel: PHYSICAL_DRIVE: 3: DISK<N:3/4,hdi(56,0),ID:3,PT:1,SZ:2930256688,ST:P :online>
Feb 8 13:32:08 data kernel: CURRENT_DRIVE : DISK<N:1/2,XXX(33,0),ID:1,PT:1,SZ:2930256688,ST: :online>
Feb 8 13:32:08 data kernel: Need to do drives searching.
Feb 8 13:32:08 data kernel: Need to find leftover drive,total=4,ready=3
Feb 8 13:32:08 data kernel: Found leftover disk in old cfg: position=1
Feb 8 13:32:08 data kernel: Copy leftover disk: position=1
Feb 8 13:32:08 data kernel: Find p d at 3, chn 3
Feb 8 13:32:08 data kernel: drive 0 missing
Feb 8 13:32:08 data kernel: Total=4; raid=4; ready=0; work=4; failed=0
Feb 8 13:32:08 data kernel: Needed drive missing (1), Take it out from XRAID.
Feb 8 13:32:08 data kernel: Change device 0 online indicater from 0 to 0 present = 1
Feb 8 13:32:08 data kernel: Drive failed on channel 0, remove this drive..
Feb 8 13:32:08 data kernel: Check degraded mode, start_pos=1
Feb 8 13:32:08 data kernel: Error: ide1 need to be non-present, but is.
Feb 8 13:32:08 data kernel: Drive 1 present, state=0/FYT, 1
Feb 8 13:32:08 data kernel: Drive 2 present, state=1/ACT
Feb 8 13:32:08 data kernel: Drive 3 present, state=1/ACT
Feb 8 13:32:08 data kernel: Drive 4 present, state=1/ACT
Feb 8 13:32:08 data kernel: Need to run X_RAID in degraded mode, total dead=1
Feb 8 13:32:08 data kernel: Adding active interface 1 as failed interface 1
Feb 8 13:32:08 data kernel: Adding missing drive in 1, add=1 morethanproc=1, disk=0
Feb 8 13:32:08 data kernel: Add dead device for not only disk, true device not changed.
Feb 8 13:32:08 data kernel: Dump hwif 8041daa0 structure, 0-8041d398
Feb 8 13:32:08 data kernel: 1-8041daa0|1-8041e1a8|1-8041e8b0|1-8041efb8
Feb 8 13:32:08 data kernel: 0-8041f6c0|0-8041fdc8|0-804204d0|1-80420bd8
Feb 8 13:32:08 data kernel: hwif->name---------------------ide1
Feb 8 13:32:08 data kernel: hwif->hwgroup------------------81e9a740
Feb 8 13:32:08 data kernel: hwif->irq----------------------32
Feb 8 13:32:08 data kernel: hwif->present------------------1
Feb 8 13:32:08 data kernel: hwif->hold---------------------1
Feb 8 13:32:08 data kernel: hwif->noprobe^I^I^I0
Feb 8 13:32:08 data kernel: hwif->true_device^I^I0
Feb 8 13:32:08 data kernel: hwif->state0^I^I^I0
Feb 8 13:32:08 data kernel: hwif->drives[0].name----------hdc
Feb 8 13:32:08 data kernel: hwif->drives[0].present-------0
Feb 8 13:32:08 data kernel: hwif->drives[0].id_read-------0
Feb 8 13:32:08 data kernel: hwif->drives[0].noprobe^I1
Feb 8 13:32:08 data kernel: hwif->drives[0].dead^I^I0
Feb 8 13:32:08 data kernel: hwif->drives[0].id^I^I81e9af40
Feb 8 13:32:08 data kernel: hwif->drives[1].present-------0
Feb 8 13:32:08 data kernel: hwif->drives[1].id_read-------0
Feb 8 13:32:08 data kernel: ATA DISK drive 8041db38
Feb 8 13:32:08 data kernel: hdc: ST2000DM001-1CH164, hdc: enable ATAEXT
Feb 8 13:32:08 data kernel: hwif->drives[0].id_read-------1
Feb 8 13:32:08 data kernel: hwif->drives[0].dead^I^I1
Feb 8 13:32:08 data kernel: Add dead device not present and allow master sector.
Feb 8 13:32:08 data kernel: Link drive hdc to its hwgroup.
Feb 8 13:32:08 data kernel: hdc: max request size: 512KiB
Feb 8 13:32:08 data kernel: hdc: use capacity 3907029168 sectors (2000398 MB)
Feb 8 13:32:08 data kernel: :<6>hdc: 3907008688 sectors (2000388 MB), CHS=65535/255/63
Feb 8 13:32:08 data kernel: ::<6> hdc: (Fix non bootable low sector,flag=0x34) hdc1 hdc2 hdc3 < hdc5 hdc6 >
Feb 8 13:32:08 data kernel: idedisk_deaddisk_init on hdc
Feb 8 13:32:08 data kernel: ide-disk: hdc: from special init, need to reset values.
Feb 8 13:32:08 data kernel: Change X_RAID running mode from 0 to 1
Feb 8 13:32:08 data kernel: ::::Update backup SB.
Feb 8 13:32:08 data kernel: Forced to write the SB, since there is a drive down.
Feb 8 13:32:08 data kernel: Update time for sb 2 = 5115446a.
Feb 8 13:32:08 data kernel: Update time for sb 3 = 5115446a.
Feb 8 13:32:08 data kernel: Update time for sb 4 = 5115446a.
Feb 8 13:32:08 data kernel: Selected sb 2, ctime=5115446a, id=a2014319.
Feb 8 13:32:08 data kernel: VERSION/ID : SB=(V:0.1.0) ID=<a2014319.00000000.00000000.00000000> CT:5115446a
Feb 8 13:32:08 data kernel: RAID_INFO : DISKS(TOTAL:4 RAID:4 PARITY:3 ONL:3 WRK:3 FAILED:1 SPARE:0 BASE:0)
Feb 8 13:32:08 data kernel: LOGICAL_DRIVE : 0: B:0000000002 E:0004096000 R:1 O:1 I:0:000000000 DM:e
Feb 8 13:32:08 data kernel: LOGICAL_DRIVE : 1: B:0004096002 E:2926160686 R:4 O:1 I:0:000000000 DM:e
Feb 8 13:32:08 data kernel: PHYSICAL_DRIVE: 0: DISK<N:0/1,hdc(22,0),ID:0,PT:1,SZ:3907008688,ST: B:faulty>
Feb 8 13:32:08 data kernel: Total=4; raid=4; ready=0; work=3; failed=1
Feb 8 13:32:08 data kernel: X_RAID: recovery thread got woken up ...
Feb 8 13:32:08 data kernel: No drive to use, stop recovery.
Feb 8 13:32:08 data kernel: :<6> hdc: hdc1 hdc2 hdc3 < hdc5 hdc6 >
Feb 8 13:32:08 data kernel: :<6> hde: hde1 hde2 hde3 < hde5 hde6 >
Feb 8 13:32:08 data kernel: :<6> hdg: hdg1 hdg2 hdg3 < hdg5 hdg6 >
Feb 8 13:32:08 data kernel: :<6> hdi: unknown partition table
Feb 8 13:32:08 data kernel: kjournald starting. Commit interval 5 seconds
Feb 8 13:32:08 data kernel: EXT3 FS on hdc1, internal journal
Feb 8 13:32:08 data kernel: EXT3-fs: mounted filesystem with ordered data mode.
Feb 8 13:32:08 data kernel: linked, 1000mbps mode
Feb 8 13:32:08 data kernel: CMD to offline/lost_intr chn(0): 80f0bae0
Feb 8 13:32:08 data kernel: ::::::<6>kjournald starting. Commit interval 5 seconds
Feb 8 13:32:08 data kernel: EXT3-fs: mounted filesystem with journal data mode.
Feb 8 13:32:08 data kernel: Adding 255968k swap on /dev/hdc2. Priority:0 extents:1 across:255968k
Feb 8 13:32:08 data kernel: Adding 255968k swap on /dev/hde2. Priority:0 extents:1 across:255968k
Feb 8 13:32:08 data kernel: Adding 255968k swap on /dev/hdg2. Priority:0 extents:1 across:255968k
Feb 8 13:32:08 data kernel: enable_irq(11) unbalanced from f804059c
Feb 8 13:32:08 data kernel: CMD to offline/lost_intr chn(0): 812f7ae0
Feb 8 13:32:08 data kernel: :<6>hde: cache flushes supported
Feb 8 13:32:08 data kernel: :<6>hdg: cache flushes supported
Feb 8 13:32:08 data kernel: :<6>hdi: cache flushes supported
Feb 8 13:32:08 data kernel: Out of XRAID area, block=3907008672, sectors=16
Feb 8 13:32:08 data kernel: Device not exist, return NO_TOUCH.
Feb 8 13:32:08 data kernel: Cannot access channel 0, block rq (3907008672/16).
Feb 8 13:32:08 data kernel: ::::::::<6>kjournald starting. Commit interval 5 seconds
Feb 8 13:32:08 data kernel: EXT3 FS on dm-1, internal journal
Feb 8 13:32:09 data kernel: Out of XRAID area, block=3907008672, sectors=16
Feb 8 13:32:09 data kernel: Device not exist, return NO_TOUCH.
Feb 8 13:32:09 data kernel: Cannot access channel 0, block rq (3907008672/16).
Feb 8 13:33:21 data syslogd 1.4.1#10: restart.
Feb 8 13:33:37 data kernel: ::::::::::<6>ehci_hcd 0000:00:17.2: EHCI Host Controller
Feb 8 13:33:37 data kernel: ehci_hcd 0000:00:17.2: new USB bus registered, assigned bus number 1
Feb 8 13:33:37 data kernel: ehci_hcd 0000:00:17.2: irq 27, io mem 0x5c010000
Feb 8 13:33:37 data kernel: ehci_hcd 0000:00:17.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Feb 8 13:33:37 data kernel: usb usb1: configuration #1 chosen from 1 choice
Feb 8 13:33:38 data kernel: hub 1-0:1.0: USB hub found
Feb 8 13:33:38 data kernel: hub 1-0:1.0: 4 ports detected
Feb 8 13:33:38 data kernel: usb 1-3: new high speed USB device using ehci_hcd and address 2
Feb 8 13:33:38 data kernel: usb 1-3: configuration #1 chosen from 1 choice
Feb 8 13:33:39 data kernel: USB Universal Host Controller Interface driver v3.0
Feb 8 13:33:39 data kernel: PCI: VIA IRQ fixup for 0000:00:17.0, from 0 to 11
Feb 8 13:33:39 data kernel: uhci_hcd 0000:00:17.0: UHCI Host Controller
Feb 8 13:33:39 data kernel: uhci_hcd 0000:00:17.0: new USB bus registered, assigned bus number 2
Feb 8 13:33:39 data kernel: uhci_hcd 0000:00:17.0: irq 27, io base 0x5c001000
Feb 8 13:33:40 data kernel: usb usb2: configuration #1 chosen from 1 choice
Feb 8 13:33:40 data kernel: hub 2-0:1.0: USB hub found
Feb 8 13:33:40 data kernel: hub 2-0:1.0: 2 ports detected
Feb 8 13:33:41 data kernel: PCI: VIA IRQ fixup for 0000:00:17.1, from 0 to 11
Feb 8 13:33:41 data kernel: uhci_hcd 0000:00:17.1: UHCI Host Controller
Feb 8 13:33:41 data kernel: uhci_hcd 0000:00:17.1: new USB bus registered, assigned bus number 3
Feb 8 13:33:41 data kernel: uhci_hcd 0000:00:17.1: irq 27, io base 0x5c001020
Feb 8 13:33:41 data kernel: usb usb3: configuration #1 chosen from 1 choice
Feb 8 13:33:41 data kernel: hub 3-0:1.0: USB hub found
Feb 8 13:33:41 data kernel: hub 3-0:1.0: 2 ports detected
Feb 8 13:33:43 data kernel: SCSI subsystem initialized
Feb 8 13:33:43 data kernel: Initializing USB Mass Storage driver...
Feb 8 13:33:43 data kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Feb 8 13:33:43 data kernel: usbcore: registered new driver usb-storage
Feb 8 13:33:43 data kernel: USB Mass Storage support registered.
Feb 8 13:33:45 data kernel: Out of XRAID area, block=3907008672, sectors=16
Feb 8 13:33:45 data kernel: Device not exist, return NO_TOUCH.
Feb 8 13:33:45 data kernel: Cannot access channel 0, block rq (3907008672/16).
Feb 8 13:33:54 data kernel: Vendor: SanDisk Model: Cruzer Mini Rev: 0.2
Feb 8 13:33:54 data kernel: Type: Direct-Access ANSI SCSI revision: 02
Feb 8 13:33:54 data kernel: SCSI device sda: 1000944 512-byte hdwr sectors (512 MB)
Feb 8 13:33:54 data kernel: sda: Write Protect is off
Feb 8 13:33:54 data kernel: sda: sda1
Feb 8 13:33:54 data kernel: sd 0:0:0:0: Attached scsi removable disk sda
Feb 8 13:33:54 data scsi.agent: disk at /devices/pci0000:00/0000:00:17.2/usb1/1-3/1-3:1.0/host0/target0:0:0/0:0:0:0
Feb 8 13:33:59 data usb.agent: ... no modules for USB product 0/0/206
Feb 8 13:34:04 data last message repeated 2 times
Feb 8 13:34:23 data kernel: ::::
Feb 8 13:34:23 data kernel: CMD to offline/lost_intr chn(0): b8a53ae0
Feb 8 13:34:33 data kernel: X_RAID_DUMP
Feb 8 13:34:33 data kernel: VERSION/ID : SB=(V:0.1.0) ID=<a2014319.00000000.00000000.00000000> CT:5115446a
Feb 8 13:34:33 data kernel: RAID_INFO : DISKS(TOTAL:4 RAID:4 PARITY:3 ONL:3 WRK:3 FAILED:1 SPARE:0 BASE:0)
Feb 8 13:34:33 data kernel: SZ:2930256688 UT:00000000 STATE:0 LUNS:2 EXTCMD:1 LSZ:2930256686
Feb 8 13:34:33 data kernel: LOGICAL_DRIVE : 0: B:0000000002 E:0004096000 R:1 O:1 I:0:000000000 DM:e
Feb 8 13:34:33 data kernel: LOGICAL_DRIVE : 1: B:0004096002 E:2926160686 R:4 O:1 I:0:000000000 DM:e
Feb 8 13:34:33 data kernel: PHYSICAL_DRIVE: 0: DISK<N:0/1,hdc(22,0),ID:0,PT:1,SZ:3907008688,ST: B:faulty>
Feb 8 13:34:33 data kernel: PHYSICAL_DRIVE: 1: DISK<N:1/2,hde(33,0),ID:1,PT:1,SZ:2930256688,ST: :online>
Feb 8 13:34:33 data kernel: PHYSICAL_DRIVE: 2: DISK<N:2/3,hdg(34,0),ID:2,PT:1,SZ:2930256688,ST: :online>
Feb 8 13:34:33 data kernel: PHYSICAL_DRIVE: 3: DISK<N:3/4,hdi(56,0),ID:3,PT:1,SZ:2930256688,ST:P :online>
Feb 8 13:34:33 data kernel: CURRENT_DRIVE : DISK<N:1/2,XXX(33,0),ID:1,PT:1,SZ:2930256688,ST: :online>
Feb 8 13:34:33 data kernel: CURRENT_DRIVE : DISK<N:2/3,XXX(34,0),ID:2,PT:1,SZ:2930256688,ST: :online>
Feb 8 13:34:33 data kernel: CURRENT_DRIVE : DISK<N:3/4,XXX(56,0),ID:3,PT:1,SZ:2930256688,ST:P :online>
Feb 8 13:34:33 data kernel: RUN_PARAMETERS: raid_running=1,last_word=ok,interface_start_at=1,fake=0
Feb 8 13:34:33 data kernel: RAID_REBUILD : sync=0,logical=0,parity=0,sectors/TOTAL=0/4294967295
Feb 8 13:34:33 data kernel: : source=e, total_drives=3, auto_sync=1
Feb 8 13:34:33 data kernel: RAID_P_CHECK : chck=0,logical/total=0/2,raid_level=0
Feb 8 13:34:33 data kernel: : err/sectors/TOTAL=0/0/0,report_err=1
Feb 8 13:34:33 data kernel: : initialized=0xe,initialize_error=0x0,initializing=0x0
Feb 8 13:34:33 data kernel: : where=0,total=0
Feb 8 13:34:33 data kernel: SIZE_INFOR : sb_size=9440,sections_size=32/256,disk_t_size=128
Feb 8 13:34:33 data kernel: : sb=f8134294,disks=512/1536,luns=2048/3168,thisdisk=5216/128,diskid=5344/4096
Feb 8 13:34:33 data kernel: DJO_RECORD : dj_raid=X_1,chns=1,source=1f,disks=0 parity=1,chn_image=e,
Feb 8 13:34:33 data kernel: : sectors=28386/0x6ee2,need_IO=0
Feb 8 13:34:33 data kernel: IO__RECORD : 0=218830,1=19360,2=39802,3=528, busy=0/0/0/0/0,t_d=e
Feb 8 13:35:51 data kernel: ::::::==== SATA init channel 0
Feb 8 13:35:51 data kernel: After INIT SATA channel 0, retry=6128, sata=113, status=50
Feb 8 13:35:51 data kernel: --> SATA Hot add event on chn 0, 63104/60007084
Feb 8 13:35:51 data kernel: hwif->irq = 32, add 1
Feb 8 13:35:51 data kernel: XRAID on, should re-scan the drive after drive inited.
Feb 8 13:35:51 data kernel: After re-id drive, drive_failure = 0
Feb 8 13:35:51 data kernel: sata_hotplug: /sbin/hotplug add hdcUser mode helper start.
Feb 8 13:35:51 data kernel: done do_sata_hotplug
Feb 8 13:35:58 data RAIDiator: Hotplug disk event detected (data) : Disk add event occurred on SATA channel 1.\n\n[Fri Feb 8 13:35:51 EST 2013]
Feb 8 13:35:58 data kernel: X_RAID_ADD_NO_INIT 0
Feb 8 13:35:58 data kernel: Doing re_init_drive_status for XRAID real values.
Feb 8 13:35:58 data kernel: update_drive_id on hdc
Feb 8 13:35:59 data kernel: No TLER on ST2000DM001-1CH164 ^P\200@
Feb 8 13:35:59 data kernel: hdc: ST2000DM001-1CH164 (s/n:Z1E2DV0D), ATA DISK drive (ATAEXT)
Feb 8 13:35:59 data kernel: hdc: max request size: 512KiB
Feb 8 13:35:59 data kernel: hdc: use capacity 3907029168 sectors (2000398 MB)
Feb 8 13:35:59 data kernel: Drive support hpa, still should not change max addr.
Feb 8 13:35:59 data kernel: :<6>hdc: 3907008688 sectors (2000388 MB), CHS=65535/255/63
Feb 8 13:35:59 data kernel: :new mode = ST2000DM001-1CH164, new size = 3907008688, old size = 2930256686
Feb 8 13:35:59 data kernel: Adding missing drive in 1, add=1 morethanproc=1, disk=1
Feb 8 13:35:59 data kernel: Dump hwif 8041daa0 structure, 0-8041d398
Feb 8 13:35:59 data kernel: 1-8041daa0|1-8041e1a8|1-8041e8b0|1-8041efb8
Feb 8 13:35:59 data kernel: 0-8041f6c0|0-8041fdc8|0-804204d0|1-80420bd8
Feb 8 13:35:59 data kernel: hwif->name---------------------ide1
Feb 8 13:35:59 data kernel: hwif->hwgroup------------------81e9a740
Feb 8 13:35:59 data kernel: hwif->irq----------------------32
Feb 8 13:35:59 data kernel: hwif->present------------------1
Feb 8 13:35:59 data kernel: hwif->hold---------------------1
Feb 8 13:35:59 data kernel: hwif->noprobe^I^I^I0
Feb 8 13:35:59 data kernel: hwif->true_device^I^I0
Feb 8 13:35:59 data kernel: hwif->state0^I^I^I1
Feb 8 13:35:59 data kernel: hwif->drives[0].name----------hdc
Feb 8 13:35:59 data kernel: hwif->drives[0].present-------1
Feb 8 13:35:59 data kernel: hwif->drives[0].id_read-------1
Feb 8 13:35:59 data kernel: hwif->drives[0].noprobe^I0
Feb 8 13:35:59 data kernel: hwif->drives[0].dead^I^I0
Feb 8 13:35:59 data kernel: hwif->drives[0].id^I^I81e9af40
Feb 8 13:35:59 data kernel: hwif->drives[1].present-------0
Feb 8 13:35:59 data kernel: hwif->drives[1].id_read-------0
Feb 8 13:35:59 data kernel: ATA DISK drive 8041db38
Feb 8 13:35:59 data kernel: hdc: ST2000DM001-1CH164, hdc: enable ATAEXT
Feb 8 13:35:59 data kernel: hwif->drives[0].dead^I^I1
Feb 8 13:35:59 data kernel: Add dead device for only disk, true device set to 0.
Feb 8 13:35:59 data kernel: idedisk_deaddisk_init on hdc
Feb 8 13:35:59 data kernel: ide-disk: hdc: from special init, need to reset values.
Feb 8 13:35:59 data kernel: Drive need to be inited, will add after initialization.
Feb 8 13:35:59 data kernel: Disk number= 1: true=0, d=8041db38
Feb 8 13:35:59 data kernel: Disk number= 2: true=1, d=8041e240
Feb 8 13:35:59 data kernel: Disk number= 2, true device.
Feb 8 13:35:59 data kernel: Disk number= 3: true=1, d=8041e948
Feb 8 13:35:59 data kernel: Disk number= 3, true device.
Feb 8 13:35:59 data kernel: Disk number= 4: true=1, d=8041f050
Feb 8 13:35:59 data kernel: Disk number= 4, true device.
Feb 8 13:35:59 data kernel: life_chn=e, new_chn=0
Feb 8 13:35:59 data kernel: No free drive to add for (init/expand) on.
Feb 8 13:35:59 data kernel: Init drives on 1
Feb 8 13:35:59 data kernel: X_RAID command failed
Feb 8 13:35:59 data kernel: ::Prepare drive hdc, size=3907008688
Feb 8 13:35:59 data kernel: Sending init start event.
Feb 8 13:35:59 data kernel: Select r_model ID at 0(1), ST2000DM001-1CH164, CC24
Feb 8 13:35:59 data kernel: New drive size checking: 3907008688 / 2930256688.
Feb 8 13:35:59 data kernel: Checking BUSY....
Feb 8 13:35:59 data kernel: Send SECURITY SET PASSWORD command
Feb 8 13:35:59 data kernel: Wait completion
Feb 8 13:35:59 data kernel: Security Set Password command succeed
Feb 8 13:35:59 data kernel: Send SECURITY ERASE UNIT command
Feb 8 13:35:59 data kernel: Take drive out from channel 0, block access to it.
Feb 8 13:35:59 data kernel: sata_hotplug: /sbin/hotplug xraid_disk_init_started hdcUser mode helper start.
Feb 8 13:35:59 data kernel: done do_sata_hotplug
Feb 8 13:35:59 data kernel: :<6>hde: cache flushes supported
Feb 8 13:36:00 data kernel: :<6>hdg: cache flushes supported
Feb 8 13:36:00 data kernel: :<6>hdi: cache flushes supported
Feb 8 13:36:02 data kernel: Out of XRAID area, block=3907008672, sectors=16
Feb 8 13:36:02 data kernel: Device not exist, return NO_TOUCH.
Feb 8 13:36:02 data kernel: Cannot access channel 0, block rq (3907008672/16).
Feb 8 13:36:11 data RAIDiator: RAID event detected (data) : Disk initialization started. The estimated time of completion is 17 hour(s) and 39 minute(s), at which time you will be notified via email. You can also check the progress in Frontview in the Volumes -> RAID Settings tab. Please do not shutdown the system while the initialization is in progress.\n\n[Fri Feb 8 13:35:59 EST 2013]
Feb 8 13:36:24 data kernel: :::::::::::Out of XRAID area, block=3907008672, sectors=16
Feb 8 13:36:24 data kernel: Device not exist, return NO_TOUCH.
Feb 8 13:36:24 data kernel: Cannot access channel 0, block rq (3907008672/16).
Feb 8 17:04:26 data kernel: :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::Put drive into channel 0, allow access to it.
Feb 8 17:04:26 data kernel: Sending init done event.
Feb 8 17:04:26 data kernel: disk_init_finished on 0,how_many=1,selected=1,Present=1, state=0, init_hd=0, sync=0, change_cfg=0
Feb 8 17:04:26 data kernel: 1 new drive checked on chn 0.
Feb 8 17:04:26 data kernel: WRITE erased flag 0=0
Feb 8 17:04:26 data kernel: Drive 0 passed init and test, add to array.
Feb 8 17:04:26 data kernel: sata_hotplug: /sbin/hotplug xraid_disk_init_finished hdcUser mode helper start.
Feb 8 17:04:26 data kernel: done do_sata_hotplug
Feb 8 17:04:26 data kernel: No TLER on ST2000DM001-1CH164 ^P\200@
Feb 8 17:04:26 data kernel: hdc: ST2000DM001-1CH164 (s/n:Z1E2DV0D), ATA DISK drive (ATAEXT)
Feb 8 17:04:26 data kernel: hdc: max request size: 512KiB
Feb 8 17:04:26 data kernel: hdc: use capacity 3907029168 sectors (2000398 MB)
Feb 8 17:04:26 data kernel: Drive support hpa, still should not change max addr.
Feb 8 17:04:26 data kernel: :<6>hdc: 3907008688 sectors (2000388 MB), CHS=65535/255/63
Feb 8 17:04:26 data kernel: :<6>hdc: cache flushes supported
Feb 8 17:04:26 data kernel: New drive information on chn 0 updated.
Feb 8 17:04:26 data kernel: ::Saved ID buffer from 1
Feb 8 17:04:26 data kernel: Saved ID buffer from 2
Feb 8 17:04:26 data kernel: Saved ID buffer from 3
Feb 8 17:04:26 data kernel: Saved ID buffer from 4
Feb 8 17:04:26 data kernel: ext.
Feb 8 17:04:26 data last message repeated 3 times
Feb 8 17:04:26 data kernel: :::::1 WARNING: COD diff,disk 0 and 8, raid_disks 0 != 3
Feb 8 17:04:26 data kernel: :1 WARNING: COD diff,disk 0 and 9, raid_disks 0 != 3
Feb 8 17:04:26 data kernel: :1 WARNING: COD diff,disk 0 and 10, raid_disks 0 != 3
Feb 8 17:04:26 data kernel: :1 WARNING: COD diff,disk 0 and 11, raid_disks 0 != 3
Feb 8 17:04:26 data kernel: Auto sync is on
Feb 8 17:04:26 data kernel: X_RAID: recovery thread got woken up ...
Feb 8 17:04:26 data kernel: New = 0, source drives = e, current/active=3/4
Feb 8 17:04:26 data kernel: Prepare sync raid 1, source_image=e, sync=3, ready=0
Feb 8 17:04:26 data kernel: Start sync:0, source_image=2/0, between 2 to 4096002
Feb 8 17:04:26 data kernel: sata_hotplug: /sbin/hotplug xraid_sync_started hdcUser mode helper start.
Feb 8 17:04:27 data kernel: :<6>hde: cache flushes supported
Feb 8 17:04:27 data kernel: :<6>hdg: cache flushes supported
Feb 8 17:04:28 data kernel: :<6>hdi: cache flushes supported
Feb 8 17:04:28 data kernel: :<6>hdc: cache flushes supported
Feb 8 17:04:37 data RAIDiator: RAID event detected (data) : RAID sync started on volume C.\n\n[Fri Feb 8 17:04:27 EST 2013]
Feb 8 17:04:38 data kernel: Out of XRAID area, block=3907008672, sectors=16
Feb 8 17:04:38 data RAIDiator: RAID event detected (data) : Disk initialization successfully finished.\n\n[Fri Feb 8 17:04:27 EST 2013]
Feb 8 17:05:02 data kernel: ::::::::::::::::Sync:2, source_image=2/2, between 2 to 4096002,all_tgt=e
Feb 8 17:05:35 data kernel: :Sync:3, source_image=2/3, between 2 to 4096002,all_tgt=e
Feb 8 17:06:07 data kernel: :::Start sync raid 4 from 4096002 to 2930256688
Feb 8 23:49:38 data kernel: ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::0 4 4 4 4 55 0 16
Feb 8 23:49:38 data kernel: 0 1 1 1
Feb 8 23:49:38 data kernel: 1 0 1 1
Feb 8 23:49:38 data kernel: 1 1 0 1
Feb 8 23:49:38 data kernel: 1 1 1 0
Feb 8 23:49:38 data kernel: Update time for sb 1 = 5115766a.
Feb 8 23:49:38 data kernel: Update time for sb 2 = 5115766a.
Feb 8 23:49:38 data kernel: Update time for sb 3 = 5115766a.
Feb 8 23:49:38 data kernel: Update time for sb 4 = 5115766a.
Feb 8 23:49:38 data kernel: recent_ID = 1, select_ID=1, most_ID=4 right_mac=4
Feb 8 23:49:38 data kernel: Selected sb 1, ctime=5115766a, id=a2014319.
Feb 8 23:49:38 data kernel: Use this image: 1
Feb 8 23:49:38 data kernel: VERSION/ID : SB=(V:0.1.0) ID=<a2014319.00000000.00000000.00000000> CT:5115766a
Feb 8 23:49:38 data kernel: RAID_INFO : DISKS(TOTAL:4 RAID:4 PARITY:3 ONL:4 WRK:4 FAILED:0 SPARE:0 BASE:0)
Feb 8 23:49:38 data kernel: SZ:2930256688 UT:00000000 STATE:0 LUNS:2 EXTCMD:1 LSZ:2930256686
Feb 8 23:49:38 data kernel: LOGICAL_DRIVE : 0: B:0000000002 E:0004096000 R:1 O:1 I:1:000000000 DM:f
Feb 8 23:49:38 data kernel: LOGICAL_DRIVE : 1: B:0004096002 E:2926160686 R:4 O:1 I:1:000000000 DM:e
Feb 8 23:49:38 data kernel: PHYSICAL_DRIVE: 0: DISK<N:0/1,hdc(22,0),ID:0,PT:1,SZ:3907008688,ST: B:online>
Feb 8 23:49:38 data kernel: PHYSICAL_DRIVE: 1: DISK<N:1/2,hde(33,0),ID:1,PT:1,SZ:2930256688,ST: :online>
Feb 8 23:49:38 data kernel: PHYSICAL_DRIVE: 2: DISK<N:2/3,hdg(34,0),ID:2,PT:1,SZ:2930256688,ST: :online>
Feb 8 23:49:38 data kernel: PHYSICAL_DRIVE: 3: DISK<N:3/4,hdi(56,0),ID:3,PT:1,SZ:2930256688,ST:P :online>
Feb 8 23:49:38 data kernel: CURRENT_DRIVE : DISK<N:0/1,XXX(22,0),ID:0,PT:1,SZ:3907008688,ST: B:online>
Feb 8 23:49:38 data kernel: Total=4; raid=4; ready=0; work=4; failed=0
Feb 8 23:49:38 data kernel: sata_hotplug: /sbin/hotplug xraid_sync_finished hdcUser mode helper start.
Feb 8 23:49:38 data kernel: done do_sata_hotplug
Feb 8 23:49:45 data RAIDiator: RAID event detected (data) : RAID sync finished on volume C. The volume is now fully redundant.\n\n[Fri Feb 8 23:49:39 EST 2013]
Feb 9 01:46:51 data kernel: ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::chn=1, statu/LP_S=0x(d0/d050)29, 8
Feb 9 01:47:13 data kernel: LPCH_ACTIVE still on: 10
Feb 9 01:47:13 data kernel: 2req = 1 80fa21d0,00000000,00000000,00000000 1
Feb 9 01:47:14 data kernel: LPCH_ACTIVE still on: 10
Feb 9 01:47:14 data kernel: 2req = 1 80fa21d0,00000000,00000000,00000000 1
Feb 9 01:47:15 data kernel: LPCH_ACTIVE still on: 10
Feb 9 01:50:12 data kernel: 2req = 1 80fa21d0,00000000,00000000,00000000 1
Feb 9 01:50:12 data kernel: LPCH_ACTIVE still on: 10
Feb 9 01:50:13 data kernel: LPCH_ACTIVE still on: 10
Feb 9 01:50:13 data kernel: 2req = 1 80fa21d0,00000000,00000000,00000000 1
Feb 9 01:50:13 data kernel: ****Waiting_intr for chn 0 8041db38****
Feb 9 01:50:13 data kernel: ****Waiting_intr for chn 1 00000000****
Feb 9 01:50:13 data kernel: ****Waiting_intr for chn 2 00000000****
Feb 9 01:50:13 data kernel: ****Waiting_intr for chn 3 00000000****
Feb 9 01:50:13 data kernel: ****Waiting_intr for chn 4 00000000****
Feb 9 01:50:13 data kernel: ****Waiting_intr for chn 5 00000000****
Feb 9 01:50:13 data kernel: ****Waiting_intr for chn 6 00000000****
Feb 9 01:50:13 data kernel: ****Waiting_intr for chn 7 00000000****
Feb 9 01:50:13 data kernel: ----- lp_timer_expiry:0, chn=0,status=0xd0 -----
Feb 9 01:50:13 data kernel: PADRE_SDW_STATUS d0
Feb 9 01:50:13 data kernel: PADRE_SDW_DEVHEAD e0
Feb 9 01:50:13 data kernel: PADRE_SDW_DEVCONTROL 3500d0
Feb 9 01:50:13 data kernel: PADRE_SDW_CYLHIGH 54
Feb 9 01:50:13 data kernel: PADRE_SDW_CYLLOW 32
Feb 9 01:50:13 data kernel: PADRE_SDW_SECNUMBER 7b
Feb 9 01:50:13 data kernel: PADRE_SDW_FEATURES 0
Feb 9 01:50:13 data kernel: PADRE_SDW_SECCOUNT 10
Feb 9 01:50:13 data kernel: +++++ ++++++++++++++++++++++++++++++++++++++++ +++++
Feb 9 01:50:13 data kernel: PADRE_VEN_ERROR=0, PADRE_SCR_ERROR=4050000
Feb 9 01:50:13 data kernel: DMA reg=c009,400,6af1e1f0,e10
Feb 9 01:50:13 data kernel: 0,0=7fc00023,1=6af1e000,2=24001000,3=f000035,4=e0000000,5=54327b,6=10,7=4200603
Feb 9 01:50:13 data kernel: 0,0=7fc00043,1=6af1f000,2=8e001000,3=f000000,4=0,5=0,6=0,7=4200603
Feb 9 01:50:13 data kernel: lp_timer_expiry
Feb 9 01:50:13 data kernel: djo, chn=0, dj_raid=1, chns=4 source=20 disks=6 parity=3, chn_image=f sector=5517947/54327b,sects=16, need_IO=1
Feb 9 01:50:13 data kernel: djo1, chn=0, X_mode=X_4, chns=2 source=12 disks=0 parity=3, sects=5517947/54327b cmd=1
Feb 9 01:50:13 data kernel: o_djo, chn=0, X_raid=1, 4 20 6 3,got_m=0
Feb 9 01:50:13 data kernel: o_djo1, chn=0, X_raid=1, 2 12 0 3
Feb 9 01:50:13 data kernel: Need to re-set all of the sata channel f
Feb 9 01:50:13 data kernel: SDW_STATUS on drive 0 = 0xd0
Feb 9 01:50:13 data kernel: SDW_STATUS on drive 1 = 0xd0
Feb 9 01:50:13 data kernel: SDW_STATUS on drive 2 = 0xd0
Feb 9 01:50:13 data kernel: SDW_STATUS on drive 3 = 0xd0
Feb 9 01:50:13 data kernel: Reset sata channel 0
Feb 9 01:50:13 data kernel: ==== SATA init channel 0
Feb 9 01:50:13 data kernel: After INIT SATA channel 0, retry=30000, sata=113, status=d0
Feb 9 01:50:13 data kernel: Fail to get ready statu from drive.
Feb 9 01:50:13 data kernel: sata_drive_ready: not ready
Feb 9 01:50:13 data kernel: Status = d0,chn=0,retry=50000,sata_interface_ready=1, true_d=1
Feb 9 01:50:13 data kernel: sata interface=0, SCRstatus= 113,driver status=d0, hwif_present=1
Feb 9 01:50:13 data kernel: Change device 0 online indicater from 1 to 0 present = 1
Feb 9 01:50:13 data kernel: Drive failed on channel 0, remove this drive..
Feb 9 01:50:13 data kernel: 2 WARNING: COD diff,disk 0 and 4, working_disks 0 != 3, failed_disk 1 != 1,active_disks 0 != 3
Feb 9 01:50:13 data last message repeated 3 times
Feb 9 01:50:13 data kernel: Reset sata channel 1
Feb 9 01:50:13 data kernel: Need to disable irq on 1
Feb 9 01:50:13 data kernel: ==== SATA init channel 1
Feb 9 01:50:13 data kernel: After INIT SATA channel 1, retry=139, sata=113, status=50
Feb 9 01:50:13 data kernel: Need to enable irq on 1
Feb 9 01:50:13 data kernel: Reset sata channel 2
Feb 9 01:50:13 data kernel: Need to disable irq on 2
Feb 9 01:50:13 data kernel: ==== SATA init channel 2
Feb 9 01:50:13 data kernel: After INIT SATA channel 2, retry=123, sata=113, status=50
Feb 9 01:50:13 data kernel: Need to enable irq on 2
Feb 9 01:50:13 data kernel: Reset sata channel 3
Feb 9 01:50:13 data kernel: Need to disable irq on 3
Feb 9 01:50:13 data kernel: ==== SATA init channel 3
Feb 9 01:50:13 data kernel: After INIT SATA channel 3, retry=146, sata=113, status=50
Feb 9 01:50:13 data kernel: Need to enable irq on 3
Feb 9 01:50:13 data kernel: failed channel image=1
Feb 9 01:50:13 data kernel: failed_channel image=1
Feb 9 01:50:13 data kernel: Release waiting_for_dma flag 0
Feb 9 01:50:13 data kernel: Status = d0,chn=0,retry=50000,sata_interface_ready=1, true_d=0
Feb 9 01:50:13 data kernel: Release the req pointer 80fa21d0
Feb 9 01:50:13 data kernel: Timer out1 needIO=1, X_mode=20 hwgroup=81e9a740, irq=32
Feb 9 01:50:13 data kernel: ****Waiting_intr for chn 1 00000000 1****
Feb 9 01:50:13 data kernel: ****Waiting_intr for chn 2 00000000 0****
Feb 9 01:50:13 data kernel: ****Waiting_intr for chn 3 00000000 0****
Feb 9 01:50:13 data kernel: ****Waiting_intr for chn 4 00000000 0****
Feb 9 01:50:13 data kernel: Enable IRQ 32, on 8041daa0
Feb 9 01:50:13 data kernel: Another IRQ 32, on 81e9a740
Feb 9 01:50:13 data kernel: enable_irq(32) unbalanced from f811c118
Feb 9 01:50:13 data kernel: Warning:chn 0, there is a pending retry on req 80fa21d0, current req 80fa21d0
Feb 9 01:50:13 data kernel: hwif->irq = 32, retry 1
Feb 9 01:50:13 data kernel: sata_hotplug: /sbin/hotplug retry hdcUser mode helper start.
Feb 9 01:50:13 data kernel: hwif->irq = 32, fail 1
Feb 9 01:50:13 data kernel: sata_hotplug: /sbin/hotplug fail hdcUser mode helper start.
Feb 9 01:50:13 data kernel: done do_sata_hotplug
Feb 9 01:50:14 data kernel: Forced to write the SB, since there is a drive down.
Feb 9 01:50:14 data kernel: 0 0 3 3 3 55 0 16
Feb 9 01:50:14 data kernel: 0 0 0 0
Feb 9 01:50:14 data kernel: 0 0 1 1
Feb 9 01:50:14 data kernel: 0 1 0 1
Feb 9 01:50:14 data kernel: 0 1 1 0
Feb 9 01:50:14 data kernel: Update time for sb 1 = 0.
Feb 9 01:50:14 data kernel: Update time for sb 2 = 5115f171.
Feb 9 01:50:14 data kernel: Update time for sb 3 = 5115f171.
Feb 9 01:50:14 data kernel: Update time for sb 4 = 5115f171.
Feb 9 01:50:14 data kernel: recent_ID = 2, select_ID=2, most_ID=3 right_mac=4
Feb 9 01:50:14 data kernel: Selected sb 2, ctime=5115f171, id=a2014319.
Feb 9 01:50:14 data kernel: Use this image: 2
Feb 9 01:50:14 data kernel: VERSION/ID : SB=(V:0.1.0) ID=<a2014319.00000000.00000000.00000000> CT:5115f171
Feb 9 01:50:14 data kernel: RAID_INFO : DISKS(TOTAL:4 RAID:4 PARITY:3 ONL:3 WRK:3 FAILED:1 SPARE:0 BASE:0)
Feb 9 01:50:14 data kernel: SZ:2930256688 UT:00000000 STATE:0 LUNS:2 EXTCMD:1 LSZ:2930256686
Feb 9 01:50:14 data kernel: LOGICAL_DRIVE : 0: B:0000000002 E:0004096000 R:1 O:1 I:0:000000000 DM:e
Feb 9 01:50:14 data kernel: LOGICAL_DRIVE : 1: B:0004096002 E:2926160686 R:4 O:1 I:0:000000000 DM:e
Feb 9 01:50:14 data kernel: PHYSICAL_DRIVE: 0: DISK<N:0/1,hdc(22,0),ID:0,PT:1,SZ:3907008688,ST: B:faulty>
Feb 9 01:50:14 data kernel: PHYSICAL_DRIVE: 1: DISK<N:1/2,hde(33,0),ID:1,PT:1,SZ:2930256688,ST: :online>
Feb 9 01:50:14 data kernel: PHYSICAL_DRIVE: 2: DISK<N:2/3,hdg(34,0),ID:2,PT:1,SZ:2930256688,ST: :online>
Feb 9 01:50:14 data kernel: PHYSICAL_DRIVE: 3: DISK<N:3/4,hdi(56,0),ID:3,PT:1,SZ:2930256688,ST:P :online>
Feb 9 01:50:14 data kernel: CURRENT_DRIVE : DISK<N:1/2,XXX(33,0),ID:1,PT:1,SZ:2930256688,ST: :online>
Feb 9 01:50:14 data kernel: Total=4; raid=4; ready=0; work=3; failed=1
Feb 9 01:50:26 data RAIDiator: Disk failure detected. (data) : Disk fail event occurred on SATA channel 1.\n\nIf the failed disk is used in a RAID level 1, 5, or X-RAID volume, please note that volume is now unprotected, and an additional disk failure may render that volume dead.\n\n\n[Sat Feb 9 01:50:13 EST 2013]
Feb 9 03:00:09 data kernel: ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::<6>EXT3-fs: INFO: recovery required on readonly filesystem.
Feb 9 03:00:09 data kernel: EXT3-fs: write access will be enabled during recovery.
Feb 9 03:00:14 data kernel: kjournald starting. Commit interval 5 seconds
Feb 9 03:00:14 data kernel: EXT3-fs: recovery complete.
Feb 9 03:00:14 data kernel: EXT3-fs: mounted filesystem with ordered data mode.
Feb 9 03:00:14 data kernel: Out of XRAID area, block=3907008672, sectors=16
Feb 9 03:00:14 data kernel: Device not exist, return NO_TOUCH.
Feb 9 03:00:14 data kernel: Cannot access channel 0, block rq (3907008672/16).
Feb 9 03:00:27 data kernel: ::::::::Out of XRAID area, block=3907008672, sectors=16
Feb 9 03:00:27 data kernel: Device not exist, return NO_TOUCH.
Feb 9 03:00:27 data kernel: Cannot access channel 0, block rq (3907008672/16).
Feb 9 04:00:01 data kernel: ::::::::::::::::::::::::::::::::::::::::::::::::
Feb 9 04:00:01 data kernel: CMD to offline/lost_intr chn(0): 9e3f3ae0
Feb 9 04:20:25 data kernel: ::::::::::::LPCH_ACTIVE still on: 20
Feb 9 04:20:25 data kernel: 2req = 1 00000000,95c2f1a0,00000000,00000000 1
Feb 9 04:20:25 data kernel: LPCH_ACTIVE still on: 20
Feb 9 04:20:25 data kernel: 2req = 1 00000000,a194fc68,00000000,00000000 1
Feb 9 06:25:44 data syslogd 1.4.1#10: restart.
1 Reply
  • A follow-up: I have replaced the 1CH version of the drive with a 9YN164 and since have replaced the second of the older drives with the ST20000 9YN). The array is redundant and the system boots.
    However, this seems to be the only good news. The system is still very slow and there are a lot of LPCH-ACTIVE still on errors and all drives show a lot SATA resets in SMART data. Not sure what is happening.
    Any ideas?
ProSupport for Business
