Orbi WiFi 7 RBE973
Reply
Nas is not booking after latest firmware update
ShadowStorm
After the firmware update it was fine up untill today were it failed to boot, the power light is just flashing (Im sure its just failing to boot)
I have tried to reinstall the OS but his did not work did a little more looking around and there was the OS6 Recovery Tool but can't get it to work, i can select everything else exept the Firmware image
Nas Type: RN102
Drive Space: 2X2TB
Firmware Update: 6.6.1
Thanks to anyone that can help
Just ask if you need anymore information
Model: RN10200|ReadyNAS 100 Series 2- Bay (Diskless)
Message 1 of 3
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: Nas is not booking after latest firmware update
Then you didn't follow the USB Boot Recovery instructions. In any case this doesn't sound like an issue that USB Boot Recovery is likely to fix.
Have you been getting any SMART errors on your disks?
Have you tried powering down, removing your disks, hooking them up to your PC and testing them e.g. using SeaTools for SeaGate disks and WD Data LifeGuard Diagnostics for WD disks?
Message 2 of 3
All Replies
mdgm-ntgr
Message 2 of 3
ShadowStorm
On one of the disks but a have ordered a repalcement for it the other disk is fine
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1771 views
  • 0 kudos
  • 2 in conversation
Announcements
