Dominicf's avatar
Dominicf
Follower
Apr 04, 2020
RN102 will not update firmware
Looking for some help if possible, I bought an old readynas rn102 on fir.ware 6.0.4 and it refuses to update when I click check for update it finds an update for 6.2.4 but fails with 6001010060 and I also dow loads the firmware from netgear download page and that says unrecognized server error.
I'm not sure what else I can try so hopefully someone can point me in the right direction.
Thank you
  • JohnCM_S's avatar
    JohnCM_S
    NETGEAR Employee Retired
    Hi Dominicf,
    Welcome to the Community!
    Have you tried downloading 6.2.5 from our support website? If yes, did you get the same error message?
    You can also try using a different web browser and see if you will be able to download the firmware.
    • Sandshark's avatar
      Sandshark
      Sensei
      Usually, the "unrecognized server error" can be ignored and an update will occur anyway on reboot.  I don't recall which version that was finally fixed in, but it's well after where you are.
      Hopefully, you've already noted this, but do not update to anythng beyond 6.2.5 on your NAS at this point.  The release notes on later versions clearly warn (for good reason) to update to 6.2.5 before moving higher on a 102 or 104.
ProSupport for Business
