KorkyKat's avatar
KorkyKat
ReadyNAS Duo V2 - Rescan or Rebuild DNLA Database
I have a Netgear ReadyNAS Duo V2, which I am using as a NAS and as a DNLA Server. It has two WD MyBook external drives attached, one of which has a Media folder.
I am using a Panasonic ‘Smart TV’ to link to this and display files.
If I add files or sub-folders to the relevant folders in the Media folders, the DLNA data shown on the TV very rarely updates. It seems to need a dramatic change in the folder structure (e.g. major change in folder name, not a minor edit) to trigger a rescan or rebuild of DNLA Database. Restarting the NAS does not do a rescan, even if the ‘Check Files’ or similar option is selected.
Question:- Is there any way to force a DNLA Database Rescan or Rebuild on the NAS?
On the WD MyCloud which I am also using, these commands appear as buttons on the control screen.
NAS Detaiols:-
RND2000-200EUS
Firmware:- RAIDiator 5.3.13
Software:- 1.00.271
Thanks in anticipation!!
  • StephenB's avatar
    Other ReadyNAS do have a rescan control.  5.3.x firmware might too, but I am not seeing it in the manual (and don't own any v2 NAS).
    But you should be able to force a rescan by turning ReadyDLNA off, and then on again.
    • KorkyKat's avatar
      KorkyKat
      Thanks,
      I can't find it in manual, either.Can't find it on software either. Where would it be on other NAS systems? I will look again.
      I assumed 'Restart' would be equivalent to 'Turn off and on again', as it is in Windows. Perhaps an incorrect assumption, I'll try that.
      K
      • StephenB's avatar
        To be clear, I'm suggesting turning ReadyDLNA on and off - not the same as restarting the NAS.
        With OS-4 and OS-6 systems, it is on the main service page for ReadyDLNA.  There's a "rescan" button right next to "autoscan".
        Not sure what would happen if you turn autoscan off - that might give you the ability to manually scan.  Since Autoscan isn't working, that might be the best option for you.
ProSupport for Business
