Retired_Member
Mar 07, 2016ReadyNAS Duo v2 and larger then 4TB disks?
My old beta Duo v2 unit is suffering a hard drive failure, and I'm pondering what to do with it long term.
Currently it has two Seagate 2TB drives. Last week, the second drive went offline which it's done a few times over the years. Normally in the past a simple reseat would kick off a rebuild. However this time, Drive 1 was also starting to see some uncorrectable errors prior to the offline event. The strain from rebuild now has drive 1 up over 800 uncorrectable errors.
Overall I'm not concerned with the data on it, as it simply provided online backups 24/7 when the noisier Ultra 4 unit might be offline. New drive time does open the question of how to move forward with the unit.
The HCL only has one 4TB drive listed, and a handful of 3TB drives. A slight upgrade from the current 2TB of available space.
OS6 seems to be out of the question due to the newer ARM NAS units using a different ARM Core then the DUO V2 unit. Without a bitrot detecting filesystem, I'm not going to move the Duo v2 into holding primary data. Prior to this failure, I was pondering revamping my entire NAS setup later this year to get BTRFS or ZFS protection somehow.
Has anyone else run any larger then 4TB drives in the Duo V2 and the ReadyNAS OS 5 releases? Ideally, if I could slot in 2x6TB drivesor larger, the unit could last me another few years without needing to be replaced.
Thanks,
-Tom
- kohdeeNETGEAR Expert
You should be able to use 4 TB drives in your NAS devices that run RAIDiator 5.3. The compatibilty list is just a list of tested drives we know worked when we tried it. You use unsupported drives at your own risk.
OS 6 does have bit rot protection, so I am a little confused on why you don't think an RN2xx device wouldn't suit you (more RAM than RN100 series, better processor, more cores).
You would probably want to consider using new drives in an OS 6 box and then using backup job to move your data from NAS to NAS.
