tdibratto
Sep 26, 2019Aspirant
ReadyNas Duo upgrade path
Hi folks my READYNAS DUO is getting old and I cannot even access it any longer from Windows unless I activate and turn on the old SMB1 protocol. Windows then disables it again as it's not secure. Is there any upgrade path that allows me to take the drives out andplace them into a new ReadyNas chassis that is more current?
- Marc_VNETGEAR Employee Retired
Welcome to the Community!
It would be best to go with the OS 6 Uints like the RN400 Series and up. There is a migration guide on how you can access the data on the new NAS. Support will assist you on this.
You just need to check on this KB Article. This is the procedure for your ReadyNAS Duo to an OS 6 Unit.
HTH
Regards
- SandsharkSensei - Experienced User
Rather than move the drives, you may want to consider using new drives in the new NAS. Then, use an RSYNC backup to copy the data from old to new. Finnally, re-designate your old NAS as your backup. I don't even have SMB enabled on my backup NAS, just RSYNC. I figure it's one more possible barrier to malware/ransomware -- it can't get there via a Windows machine.
FWIW, I"ve done the same. My own Duo is a secondary backup of some of my RN526x shares. Rsync is enabled on it, but SMB (and NFS, AFP) are disabled. It's also on a power schedule, which creates another barrier for malware/ransomware.
