claynz's avatar
claynz
Guide
Apr 14, 2022
Scrub Stuck on 56.67%
My NAS unit has been stuck on Scrub at 56.67% for a few days now, how do I fix this?
  • StephenB's avatar
    Rebooting will cancel it, though of course then you won't know what is hanging it up.
    You could query the status with ssh, if that is enabled.
    • claynz's avatar
      claynz
      Guide
      How do I query the status with ssh, I think it's enabled.
      • StephenB's avatar
        Log in as root, using the NAS admin password.
        There are actually two scrubs going on in parallel - btrfs and RAID.
        To check the RAID status you can enter
        cat /proc/mdstat
        There should be a line in there that shows resync status (and estimated finish time).
        To check the BTRFS scrub status you can enter
        btrfs scrub status /data
        (assuming XRAID here - use your actual volume name if you are using FlexRAID).
        If you have disk spindown enabled, it might go faster if you disable it for a while.  Another thing you might consider is downloading the log zip file from the admin ui, and look for any btrfs or disk-related errors.
ProSupport for Business
