Reply
Circle not sending passcode
Habuki0
Hi all,
I've recently had to reset my router I use a R7000P. The router works fine but I'm having an issue with the circle app not sending me my pass code? I just get "failed to send" it was working perfectly fine yesterday until I reset the router. Is there anyway I can get the pass code as I'd like to have the parental control in place.
Thanks
Andy
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 3
Habuki0
Re: Circle not sending passcode
Managed to solve this issue 🙂
Seems my ISP modem needed factory resetting also which I've never had to do.
But now I have my pass code and circle all working again😁
Message 2 of 3
Guru
Please post about this in the Circle app forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Good Luck
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 3 of 3
Discussion stats
  • 2 replies
  • 741 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
