Orbi WiFi 7 RBE973
Reply
MK62 - Satellite not found in Network Map
lamwing8
Follower
Trying to setup the home network with the AX1800/MK62 devices. However, the satellite seems disconnected as per the network map from app. It's either showing pink dot next to it or disappearing from the network map.
Besides, I have an old R6300v2, can it be used as part of the mesh network?
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: MK62 - Satellite not found in Network Map
Hello lamwing8,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1379 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
