- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Night hawk r7900p how to add remote management
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Night hawk r7900p how to add remote management
You can only restore while the mobile is connected to the local [W]LAN.
-> How do I enable or disable remote access on my router using the Nighthawk app?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I connected to Local and click enable remote. and go to home page on IOS apps again, and the place where it usually appear two choice to connect, one is via local and second one is via remote. and the second choice via remote is not there. (Cuz i delete by accident). so how do i add the second choice back to the apps again?
Ok, lets try this on your apps (smart phone). Make sure you are not connect to your wifi. Now Go to your nighthawk app, then you will see the remote options to connect right? Delete that remote option. and tell me how you add that option back to the app once you delete the remote options.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Don't have an R7900P at hand for a test - however this works right away as documented:
Disconnecting or closing the Nighthawk App, connect to a different network or 4G (another WiFi for now here), and voîla, the device is available for Remote Management again.
