sapphirestorm
Jan 06, 2016Follower
Parental control not working
Hi
I have been using OpenDNS only as Parental controls in Netgear Genie app have never worked. I would prefer to use Netgear genie so i have removed my network from the OpenDNS and I am trying to get Netgear genie parental controls to work. It states it is enabled and I have put the settings to moderate. When I search porn it allows me to open any porn site without a problem. no matter what I search it doesn't bring up the blocked page like it did when I only had OpenDNS doing the job. Please help :)
Hi Hebby,
Those options are the different operating modes of the router and each can be used depending on the setup of your network. If you do not have another router setup then the router mode should be the correct option.
Dexter
Community Team
