Orbi WiFi 7 RBE973
Reply
ReadySHARE Vault won't install
awit
Follower
Model R6900P    firmware V1.3.1.26
Dell XPS 13   Win10 Home  64-bit  ver 1803  OS build 17134.112
running Windows Defender      logged in as admin in Win 10
Installed Netgenie and connects to router just fine. Tried to install ReadySHARE Vault. Downloads fine from Netgear site and install begins.  Looks like it's just about finished, shows "a little housekeeping ..." on the install screen, then just sits there. Any ideas why it won't finish the install?
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 2
HitandRun
Re: ReadySHARE Vault won't install
I have exactly the same problem. I can only reinstall the same outdated vault software version. Uninstalling the old software version followed by a fresh install doesn't solve the problem. So I cannot update the vault software. Computer Dell XPS9530 - Windows 10 Pro version 1803.
Model: R7000|AC1900 Smart WIFI Router
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1438 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
