Orbi WiFi 7 RBE973
Reply
WNR2000v5 Adding an Application for QoS "Port conflicts with another rule."
bnich11
So I've been trying to understand and update the QoS on the WNR2000v5 router.
More speficially, I want to specify games that I will be running to operate at the highest priority.  The available applications do not match what I am looking for, so I need to find a way to add a new one.  For example, if I want to add League of Legends in the highest priority section, I fill in the required fields under the application "Other."  I fill in the requirements (QoS Policy for: League of Legends | Priority: Highest | Connection Type : UDP | Starting Port: 5000 and Ending Port: 5500).
When I try to add this specifc application to the list, it errors me with the status "Port conflicts with another rule"
I removed all other rules from the highest category box and can't seem to get it to work.  Any help would be greeatly appreciated.
Thanks
Message 1 of 4
TheEther
Guru
Re: WNR2000v5 Adding an Application for QoS "Port conflicts with another rule."
Perhaps there is a rule at a lower priority that conflicts with those ports.
Message 2 of 4
bnich11
Is there an easy way to check each application for a port interference?
Message 3 of 4
TheEther
Guru
Not that I'm aware of.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2978 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
