- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
nighthawk cannot remote manage router
- Mark as New
- Bookmark
- Subscribe
- Permalink
nighthawk 2.3.6.617
R6400 version: 1.0.1.46
My R6400 is enabled "Remote Login" .
Step:
1. Disable wifi from my cellular phone
2. Enable mobile network
3. Use Nighthawk app to look for my router (failed)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: nighthawk cannot remote manage router
Don't be confused: The App based Remote Management is using a cloud system, it does - different from the Remote Login on the router settings - not open the management ports to the wild Internet.
Not all router models are allowing remote management using the Nighthawk App (earlier Genie App). However, I think your R6400 should alow to enable Remote Management while being connected to the local [W]LAN -> How do I enable or disable remote access on my router using the Nighthawk app?
- Mark as New
- Bookmark
- Subscribe
- Permalink
the function degrates , true ?
Shall this function enable in the future ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
NETGEAR ® COMMUNITY
United States
jimtonic
jimtonic
4
Reply To Message
Model (Recommended - Helps the community give the best answers)
Email me when someone replies
View discussion in a popup
REPLYING TO:
schumaku
schumaku Sensei Sensei
2019-06-12 10:00 PM
Same Nightawk App functionality either way. No big impact on the performance.
My business requirement is 1. To control my router outside my home, outside my wifi range.
It does really make me uncomfortable, inconvenient l.
Not sure what you want to ask here - yes, you can enable/disable this feature later.
Haha, lets go and see.
Put it in this way. The new app should be better the former or existing one, not to degrates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm also experiencing problems with the remote management utility in the new Nighthawk app and cannot remotely manage my R7000 (which I checked to be sure has the latest firmware).
After doing the initial remote management setup in the Nighthawk app while at home and connected locally to my R7000, I thought I was all set. After just going into the Nighthawk app and selecting the 'Connect Remotely' option, I get taken to a page listing my R7000 and it reports it as 'Disconnected'. I know this is untrue because I'm watching live streamed footage from my Nest cams as I write this post.
What do I need to do to make the remote management functionality work in the Nighthawk app as it used to in the Genie app?
- Mark as New
- Bookmark
- Subscribe
- Permalink
* with my phone
* outside wifi network(using cellular network)
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jimtonic wrote:
I enabled remote control on my router, ....
A little bit vague - again, to allow remote administration access for the App, it's not about enabling the [Advanced] -> [Advanced Setup] -> Remote Management (this is for a direct Web browser based access using the Netgear DDNS URL shown on that same page), much more you have to be with the mobile App on the same local WLAN, and then associtate it with the router:
Once paired, and when away and opening the Nighthawk App it will fail on the local network, and then offer a [Connect Remotely] button.
