Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Nighthawk mesh ms80 with different SSID won't add to MK83
gwkling
Follower
I have a new MK83 package, router and 2 MS80 satellites.  Works fine.  Bought add on MS80 that has different SSID than the MK83 package, and it won't connect to the MK83 router.  Please help
Message 1 of 2
Guru
Re: Nighthawk mesh ms80 with different SSID won't add to MK83
Factory reset the MS by pressing the reset button for 15 seconds then release. Then try to sync it using the MRs sync button with the MS sync button.
Try ethernet connecting it to the MR.
Possible the MS FW is older than what your using on the current MR system which the MS would need to be updated to save version of FW.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 680 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
