aero63's avatar
aero63
Connecting to Firestick
I bought the range extender to improve signal to my Firestick. The Firestick is currently connected to my router.  I have connected the Extender to the router and plugged in adjacent to the Firestick.  When I go in settings for the Firestick it shows that it is connected to the router (marginal signal).  The same WiFi number appears in the list of available networks followed by '-Ext' which shows as very good signal.  I have clicked on that and entered my router's password but it won't connect to the Firestick.  Any suggestions ?
  • Hi aero63,
                        Did you tried connecting any other devices to check if you come across the same issue? Hope you are typing the correct password since password is case sensitive. If that is the case, try to set it up again and see if that helps.
    • aero63's avatar
      aero63
      Yes.  Have connected Kindle to it with no issues.  Have tried several times to connect Firestick using the correctly typed password but it won't connect
      • jvasanth1984's avatar
        jvasanth1984
        Virtuoso
        Hi aero63,
                            Check if it connects fine with router to see if its not an issue with firestick. If it works fine with router, check for firmware upgrade on extender if any and modify wireless channel on the router to see if that helps.
  • If you have trouble or don't see your desired network, scroll down and select Join Other Network  or Rescan. After connecting to wireless network, press the Home button to display Home Screen.
