- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ERR_SSL_VERSION_OR_CIPHER_MISMATCH on AC1200
- Mark as New
- Bookmark
- Subscribe
- Permalink
The address mywifiext .net doesn't work it gives error about broken SSL/TLS.
Found this question Issue with mywifiext.com, AC1200 EX6120 but there no IP address in manual. I also can't comment on that thread. And there are no other documentation.
What IP adress this thing is using?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ERR_SSL_VERSION_OR_CIPHER_MISMATCH on AC1200
Found a way to check the IP adress of the domain:
From the terminal use nslookup command (it works on Linux, on Windows and MacOS you may need to use different command). You need to remove the angle brackets (the form don't allow to post that text).
$ nslookup mywifi<.net>
Gives:
Address: 192.168.1.250
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
