Orbi WiFi 7 RBE973
Reply
Extender
shaz756
Extender
HI,
Need some assistance.  I have just updated my wifi and now I cannot reconnect the extender.  I have reset back to factory settings and that does not help either.
Model: EX7500|AC2200 Nighthawk X4S Tri Band WiFi Mesh Extender
Message 1 of 8
Guru
Re: Extender
"updated your wifi" ?
what exactly did you do?
Did you install a new router?
If so, what model router?
Are you setting up the extender using wps or using the installation assistant?
What firmware is on the extender?
What error are you getting from the extender or whats happening?
Details are key to helping out.
Message 2 of 8
shaz756
Re: Extender
Hi,
My internet went down and it was due to the modem.  I installed a new modem and the wifi connects to all other items in the house but
when  try to install/connect the extender I cannot get it to work.  At the moment all lights are blue except for the router which is red.
Message 3 of 8
Guru
Re: Extender
What model modem did you install?
Are you setting it up with wps or the installation assistant?
Message 4 of 8
shaz756
Re: Extender
HI,
I have tried to connect the extender using both the assistant and WPS.
Message 5 of 8
Guru
Re: Extender
Message 6 of 8
shaz756
Re: Extender
Hi,
I have the telstra modem installed - generation 2
Message 7 of 8
Guru
Re: Extender
they make a lot of modems. what actual model is it?
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1341 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
