Orbi WiFi 7 RBE973
Reply
Netgear EX6200 Logo and ethernet lights are blinking
BaselMagfory
Hello everyone,
I have had the EX6200 running with no issues not so ever. Then all of the sudden it stopped working. When I looked at the device I noticed that the Netgear logo light and the ethernet ports numbers' lights are blinking. I can't access the device at all now.
Things I have tried in a hope to revive the device but with no luck:
The 30-30-30 hard reset methods
The TFTP methods https://kb.netgear.com/19841/Reinstall-the-firmware-on-a-router-without-the-setup-CD-recovery-tool
and https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
I'm really getting desperate to fix it and would appreciate any tip.
Thank you in advance
Model: EX6200|AC1200 WiFi Range Extender
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Netgear EX6200 Logo and ethernet lights are blinking
Hello BaselMagfory
You did everything I would suggest to get it working again if its still under warranty you should contact support.
http://www.netgear.com/support/contact.aspx
DarrenM
Message 2 of 3
BaselMagfory
Thank you DarrenM for your kind reply.
Unfortunately, the device is not under warranty. I have had it for a year and 7 months. What a sad thing to pay top dollars for a product that only works for less than two years!!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3781 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
