× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Hybrid VPN and HMA tcp server has changed
gycuk1
Apprentice
In Hybrid VPN HMA appear to have changed some details on their side as the TCP no longer connects just says connecting. UDP does connect fine
If i manually setup Hybrid VPN input the script( from HMA website) for TCP it connects fine. HMA said it  changed in February 2021
This happens on the latested offical firmware and Beta.I have not tried older firmware but suspect  it will be the same .It is also happing on both  XR500 and XR700
Hope this is of some help for someone as i thought it was the FW on the router doesnt appear so. Maybe a feature could be added to update the server details for the inbult vpn servcies
Model: XR700|Nighthawk Pro Gaming Router
Message 1 of 3
Netduma-Fraser
NetDuma Partner
Re: Hybrid VPN and HMA tcp server has changed
Thanks for the report, we'll update this, well done for getting it working using the Advanced setup
Message 2 of 3
gycuk1
Apprentice
To behonest the advanced is just copy and paste so all good 🙂
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1180 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
