- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Latest firmware download
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latest firmware download
- Mark as New
- Bookmark
- Subscribe
- Permalink
For me everything works fine qos, ipv6. Very good work, thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ipv6 does not work for me, wifi lost internet today, restart helped,
further shows ipv6 prefixes on phones (ipv6 disabled)
pings in games are 15 to 20 ms higher than on isp livebox (ping 30/60)
xr500 (55/75) horrible gaming experience
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ultimo download del firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@kxndal what is your exact physical setup? What is the XR connected to?
@Bishop555 does IPv6 work for you?
@iceway_zhang can you help with the IPv6 issue for @Raf1212 please?
@Baturi the game doesn’t just use that port which is why it isn’t active all the time. Would recommend you use DumaOS Classified Games.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Issue with IPV6.
Anytime I do any changes like for example enable HT160 or disable it. IPV6 lose it properties of being applied to all devices forcing me to disable it and re-enable it for it to function once more.
Issue with QoS
Anytime I make adjustment to the Bandwith Allocation area it never seems to save and it gives an error initially RPC error 'ERROR_NOENT': Rule not found in chain
*P.S- after ignoring the message and clicking okay it would seem like it saves but then goes away eventually*
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser i have ipv6 turned off in the router which is a mystery on why it even shows up. I see in the device manager certain wifi devies have a ipv6 address which ranges from amazon to ipad and apple tv, when i look at the devices i dont see the assignments
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Bishop555 did you have it enabled previously?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser no, i've restarted these devices, when i loaded the firmware i did the whole erase procedure etc, the devices themsevles seem to operate just fine. Prior to this i was on the stable build this is the first 3.0 beta firmware that has been loaded which was yesterday afternoon
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser wrote:
@Phantombluis that when you tried to add a rule or is it just when you access the page initially?
@kxndalwhat is your exact physical setup? What is the XR connected to?
@Bishop555does IPv6 work for you?
@iceway_zhangcan you help with the IPv6 issue for @Raf1212 please?
@Baturithe game doesn’t just use that port which is why it isn’t active all the time. Would recommend you use DumaOS Classified Games.
@Netduma-Fraser It happens when you try to add any rule. No problem when you access the page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Phantomblu Okay thank you, I've made a topic for it here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/RPC-when-trying-to-add-rule-to-Traf...
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser I am draggin percentage on a device then clicking update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
My first feedback on the forum. Before i will begin, i just wanna say thank you Netduma and Netgear for this update.
The XR 500 have been flashed with the last beta (104) with tfpd and a reset to be clean. I use a Pihole for DHCP (because of Orange DNS).
Error encoutered :
IPV6 :
- [DumaOS] Error parsing line in ARP table: 'fe80::d65e:ecff:fe70:5fc0 dev br0 lladdr d4:5e:ec:70:5f:c0 STALE' -> already commented on this thread and i have disabled ipv6.
- Block Services -> doesn't work when a device have a ipv6 adresse. Maybe blocking services with mac adresses will be more effciient ?
WAN :
Orange FTTH France -> can't change the DNS. I don't use phone or TV box from Orange so adding a section in dhcp (lan) where we can change the DNS is possible (with a warning) ?
Device Manager :
Some devices appear to be offline even if they are online. They appear on the arp table and respond to ping.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
today disturbing problems, the connection to the routerlogin.net website disappeared when I tried to connect to routerlogin.com such things blocked my orange (kasperky) antivirus, restarting the router helped restore the interface
- Mark as New
- Bookmark
- Subscribe
- Permalink
I attempted to deploy this new firmware yesterday to my XR500.
Uploaded firmware via Administration > Firmware Upgrade and it loaded correctly.
Factory Reset via Administration > Backup Settings > Erase
Attempted Manual Setup
Once setup was complete I was not even able to get to the dashboard I kept getting the error "R-App not loaded please wait a minute"
I was not able to get into the router at all. I attempted a Factory Reset via Reset button and then re-uploading firmware via TFTP but no change. Browser in use was Google Chrome (Windows), Firefox, Edge & Safari but no change.
I was able to re-upload the .56 firmware via TFTP and factory reset and get the router back to operational.
Any suggestions on what's gone wrong or what I can do to make this work?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, even after following your directions. It would still seem that error occurs. I have attached the image of the error below.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@brandoff7 this has happened to quite a few users. I think when you upgrade to this latest version the router tries to do some sort of cloud sync hence the unresponsive time. I went through the same steps as you but it eventually became responsive after about 20-30 mins of just leaving it idle. @Netduma-Fraser should maybe clarify this process because if this is whats happening its not very clear to the user if there is a problem or if the behaviour is normal.
Since the first reboot and painful wait, it has been fine, apart from the reported bugs of course.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@quadrophenic wrote:@brandoff7 this has happened to quite a few users. I think when you upgrade to this latest version the router tries to do some sort of cloud sync hence the unresponsive time. I went through the same steps as you but it eventually became responsive after about 20-30 mins of just leaving it idle. @Netduma-Fraser should maybe clarify this process because if this is whats happening its not very clear to the user if there is a problem or if the behaviour is normal.
@quadrophenic appreciate the response. Ok, so doing the upgrade then waiting 20-30 minutes should let me in, interesting and very weird. I'll attempt this again on Sunday so I can test some of the other features.
It is strange how it tries to do a cloud sync but you only configure WiFi settings during manual setup, you'd think it would make sense to at least set WAN and maybe LAN settings here so you could have an internet connection to sync with. I guess they're assuming everyone has a DHCP based Internet link. My link is static which makes this process harder.
- Mark as New
- Bookmark
- Subscribe
- Permalink
will this beta work on the xr450 since they both use the same stock firmware between them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@brandoff7 how long did you wait when it said Rapp not loaded? Should load within 30 seconds or so. Also if you clear the browser cache/cookies it should work.
@iielmesswavy thank you, I have reopened our internal ticket for this and informed the developer.
@quadrophenic that shouldn’t happen any longer.
@betrhlf you can’t use this firmware file but we will release a separate version for 450.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know that you work hard, but it is starting to be disturbing that there was not a stable version yet, 104 still has problems with losing the internet today the qos page is not loading at all, a disaster, it gets worse every day
- Mark as New
- Bookmark
- Subscribe
- Permalink
not to be rude @Raf1212, but this comes with the territory of it being beta. A lot of factors can affect your router and by sounds of it something else might be affecting yours beside the router it self.
@Netduma-Fraser No problem brotha, I got you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
So my feedback about this new version :
- Like many, even with IPV6 disabled, I got this message repeating in the logs : [DumaOS] Error parsing line in ARP table: 'fe80::835b:5730:f1f5:a756 dev br0 lladdr 0c:2c:54:8f:6d:26 STALE', Saturday, Septembe
- Device manager tends to show as offline device too quickly when they are not (then they are back online a second later) like the TV when you are streaming (when it stops buffering it turns offline then online a second later when it resumes buffering)
- Speed test seems to work better
- On the geofilter, the profile list is still not the same than the one displayed the first time you set up a device (Destiny vs Destiny 2 PC for example)
Overall experience is much better for now than with the previous version
