Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 on 3.0 Beta with Virgin media
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-20
04:21 AM
2021-02-20
04:21 AM
Hi,
I posted a while back about virgin media and the XR500, trying new things as the advised setup via DMZ on the virgin hub was causing issues.
I have put the VM hub 3 into modem only mode and hooked up my XR500 as a router, I also setup a broadband monitoring graph and showing on the graph is packet loss every couple of lines. Which I do not get when setting up via the DMZ method, Could I ask what is causing this packet loss in the graph shown?
Thanks
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-20
06:07 AM
2021-02-20
06:07 AM
Re: XR500 on 3.0 Beta with Virgin media
I can't see your picture as it needs to be moderated, could you link it from imgur or attach it directly? What were the issues when using DMZ? I find modem mode is a bit flaky which is why I don't suggest it so that's likely the reason.
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-20
07:41 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-20
08:48 AM
2021-02-20
08:48 AM
If you connect the PC used to do that test direct to the VM while still in modem mode and disconnect the XR do you get the same results?
Message 4 of 4
Announcements
