× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
xr500 dumaos 3.0
andy-don
xr500 dumaos 3.0
hi, can any point me in the direction of dumaos 3.0 please. ive been told its available to all now but cant find anywhere.
Message 1 of 7
Netduma-Fraser
NetDuma Partner
Re: xr500 dumaos 3.0
3.0 is included in the latest public versions and has been for quite awhile so it's likely you're already on it if you're on the latest version.
https://kb.netgear.com/000064857/XR500-Firmware-Version-2-3-2-134
Message 2 of 7
Retired_Member
Not applicable
Yeah if not then look on the Duma OS router login website. Check if there's an update if there isn't manually installed it through the website
Message 3 of 7
andy-don
thanks, I already have it then lol.did that update when I first installed it.
Message 4 of 7
falso
Tutor
Fraser: what about XR700? 2.5+ years without update! What's your opinion on that? Is it fair for that people that spent £500 on it? And please stop with your 'soon' to be released 😞😓
Message 5 of 7
Netduma-Fraser
NetDuma Partner
Once the 500 update is out the 700 will be next, you can keep up to date with progress here: https://support.netduma.com/en/support/solutions/articles/16000132677-dumaos-firmware-progress
Message 6 of 7
Guru
last XR700 was posted last August:
https://kb.netgear.com/000065096/XR700-Firmware-Version-1-0-1-50
Was not two + years ago.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBE971 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3120 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
