× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Buy a used product
Tiazeet5
Follower
Buy a used product
Hey everyone,
I am coming here because I need help. I bought an XR500 to someone else. The used product works perfectly but I can't set up it because the registration has already been by the precedent user. How can create my own login to connect and set up the XR500.
How it's going on when you buy an XR500 to someone and not in a store or website ?
Thanks for your help.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 3
Netduma-Fraser
NetDuma Partner
Re: Buy a used product
@DarrenM @ChristineT @Christian_R can you help with this?
Message 2 of 3
DarrenM
Sr. NETGEAR Moderator
You will have to contact support to see if they are able to help.
https://www.netgear.com/support/contact.aspx
DarrenM
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 916 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
