Orbi WiFi 7 RBE973
Reply
GRC//Shields!UP//Xr500//Xr700
rxman4453
Guide
This is more of a recommendation than a support question. Is there any way we can implement a stealth mode for these routers because I have them both and keep getting this result when I run the GRC ShieldsUP test.
Message 1 of 3
Guru
Re: GRC//Shields!UP//Xr500//Xr700
What FW is currently loaded?
Message 2 of 3
Guru
Also are you testing GRC with nothing else online and connected to the router? If other devices or users are connected while you test, this will give a false positive. YOu need to test with a wired PC to the router and nothing else connected to the router, Turn OFF wifi and disconnect all LAN devices accept for the 1 test PC.
Heres results with my XR450
Two ports found open however I have others using the internet during this test so those ports are open by others:
GRC | ShieldsUP! — Port Authority Text Summary
GRC Port Authority Report created on UTC: 2018-12-10 at 23:52:16
Results from scan of ports: 0, 21-23, 25, 79, 80, 110, 113,
                            119, 135, 139, 143, 389, 443, 445,
                            1002, 1024-1030, 1720, 5000
    2 Ports Open
    0 Ports Closed
   24 Ports Stealth
   26 Ports Tested
NO PORTS were found to be CLOSED.
Ports found to be OPEN were: 80, 443
Other than what is listed above, all ports are STEALTH.
TruStealth: FAILED - NOT all tested ports were STEALTH,
                   - NO unsolicited packets were received,
                   - NO Ping reply (ICMP Echo) was received.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1841 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
