× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Help setup Nighthawk XR300
kmkm94
Follower
Hello everyone,
I was hoping to get some help on here regarding how to setup my new Netgear Nighthawk XR300 Pro Gaming Router. My main ISP is Verizon FiOS. Im hoping to get help on how to properly set it up since the XR300 doesnt have a direct COAX to plug in. I connected the main Ethernet cable to the XR300 which worked until I have to actually connect to the internet. All the LED nights were on but no internet access coming from the XR300. All the Internet access is still coming from my Verizon router. Do I need to buy a MoCa adapter? I tried Youtube but I couldnt get a clear walkthrough video on how to properly set it up. Please help!
Model: XR300|Nighthawk Pro Gaming Router
Message 1 of 4
Netduma-Fraser
NetDuma Partner
Re: Help setup Nighthawk XR300
As the XR is a router it needs to be connected to a modem/router, in this case the Verizon router in order to get internet. You will also need to go through the setup wizard on the router before you can get internet.
Message 2 of 4
joeycastiglia
I’m having the same problem you had, did you figure it out?
Message 3 of 4
Netduma-Fraser
NetDuma Partner
Have you gone through the setup wizard as above?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 853 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
