× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
How to setup ExpressVPN on Nighthawk Pro Gaming XR500 ?
Anirban
Hi,
I am gonna get ExpressVPN but can anyone tell me how to install ExpressVPN on my Nighthawk Pro Gaming XR500 router ?
Message 1 of 6
Netduma-Fraser
NetDuma Partner
Re: How to setup ExpressVPN on Nighthawk Pro Gaming XR500 ?
You'll need to obtain the OpenVPN configuration file from them, then you can paste it into the advanced section of VPN Setup.
Message 2 of 6
Anirban
But doing so will it void my routers warranty or not ?
Message 3 of 6
Netduma-Fraser
NetDuma Partner
No of course not, it's a feature on the router, we wouldn't implement anything that would void the warranty.
Message 4 of 6
Anirban
Thank you for that info 🙂 BTW can you tell me if I use ExpressVPN , can I use GEO-FILTER then ?
Message 5 of 6
Netduma-Fraser
NetDuma Partner
Yes you should still be able to use the Geo-Filter when behind the VPN.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3333 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
