- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Massive internet speed drop from router to computer
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear CM700 Modem
XR500 nighthawk router
Having massive speed drops, internet from modem direct to computer 115mbps, when running through router hardwired into computer only getting 4mbps, called internet provider and all working on there end and to router. Reset router and router is showing 115mbps upon resetting and then once fully setup running speed test is only 4mbps I am at a loss not sure if firmware is what is causing issue or some settings, firmware is up to date.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Massive internet speed drop from router to computer
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have used Qos on and with it off seleted to never but speeds are still very slow, I have run a speed test on WIFI and the wifi is getting 100mbps but the wired connnection only 4mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
here is the device manager screen
- Mark as New
- Bookmark
- Subscribe
- Permalink
PROBLEM FINALLY SOLVED.
After hours of trying to figure out what my issue was.
Windows+X
Device manager
network adapters right click to properties
Advanced
Large send offload V2 (IPv4) disabled
Large send offload V2 (IPv6) disabled
Same screen scrolled down to Speed and Duplex
set value to 1.0 GB FULL DUPLEX
I am running 110mbps now with router. Router was showing 100mbps HALF duplex in the negear router setup. Now issue is fixed and running perfect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
